Pics of my painted Engine Cover !!
All things Altima Coupe.
mpbclutch33
Car: 2008 Altima Coupe 3.5L, 6-speed, Radiant Silver.
Well I finally got bored enough to paint it. It took alot of time. The air here is soo Humid lately. I have not installed in on the car yet, because there is one area that I want to touch up first and I have to wait for the humidity to go down some. But here is what I got so far.
I used Krylon for plastic. I didn't sand after the final coat and before the clear, because I liked the kinda rough look. Turned out pretty good.
Modified by mpbclutch33 at 11:18 AM 7/12/2008
08altima35
Car: 08 Nissan Altima Coupe SE 3.5 6Spd Manny Artisan Turbo Dark Slate
looks good. , but what's up with the woodgrain engine?
dkgordon
Car: Nissan Titan
Did you try and find a paint that matched your car? Looks great
altimacoupelvr
Car: 2008 Nissan Altima Coupe 2.5S Code Red/ Blonde Interior w/ Convenience Pkg.
looks good.....me likes!!!!
mpbclutch33
No.... silver is silver. Wasn't too worried about it. Looks 1000 times better.
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
very nice
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
dangeris wrote:very nice
did mine last weekend.. but i left the sides, the top, and the center area behind the nissa symbol black for added contrast....
but i didn't like how it turned out, so i'm repeating it with a brand new engoine cover, and a 12oz aerosol spray can of Nissan K12 paint... hopwfully it'll turn out as nice as yours this time around....
did you use 1 or 2 laters of primer?
08altima35
no pics doc?
windex
Car: 2008 Altima Coupe 3.5SE
Nice job man. Seem like I have a saturday morning project.
SniperJoe
Car: 2008 Nissan Altima Coupe 3.5 SE CVT, Premium, Tech, VDC.
Very nice ... well done!
Scandinavian Flick
Car: 2008 Nissan Altima Coupe 3.5SE
dammit man..... now i have to do that to my engine, because that looks sweet.
D-Roll
Car: 08 Nissan 350Z Touring Coupe
It looks real good bro, good work
mpbclutch33
I actually didn't use any primer. I used 400-600 grit sandpaper to scuff up the plastic. Used a dish liquid solution to get all the grease and stuff off. Let it dry overnight. Taped it off the next morning. I put about 3-4 coats of base down and about 2-3 coats of clear. I am a perfectionist so there was one little spot bothering me, so I tried to fix it but ended up messing it up more. So last night I sanded out the imperfection and I will touch it up later today. If you want the smooth clean look, make sure you color sand between coats and def. before adding clear. Add your pics when you get them done. Adds a nice touch for $8 you can't beat it.
rjdmmfl1
mpbclutch33 wrote:I actually didn't use any primer. I used 400-600 grit sandpaper to scuff up the plastic. Used a dish liquid solution to get all the grease and stuff off. Let it dry overnight. Taped it off the next morning. I put about 3-4 coats of base down and about 2-3 coats of clear. I am a perfectionist so there was one little spot bothering me, so I tried to fix it but ended up messing it up more. So last night I sanded out the imperfection and I will touch it up later today. If you want the smooth clean look, make sure you color sand between coats and def. before adding clear. Add your pics when you get them done. Adds a nice touch for $8 you can't beat it.
what do you mean by "color sand"
mpbclutch33
More than likely when you use paint in a can, it is not going to go on totally smooth. There will be texture to it. If you spray the color coat and then sand it smooth with like 1000 grit without taking too much paint off and then apply the clear and wet sand again with 2000 grit, you should get a very smooth clean finish.
rjdmmfl1
mpbclutch33 wrote:More than likely when you use paint in a can, it is not going to go on totally smooth. There will be texture to it. If you spray the color coat and then sand it smooth with like 1000 grit without taking too much paint off and then apply the clear and wet sand again with 2000 grit, you should get a very smooth clean finish.
thanks my dude... I'm sending you an email now...
ESP
Car: 2008 SexyBlack A/C
Just wondering how hot the 3.5 gets?I considered painting mine, but after only a few minutes of regular driving the engine cover on my 2.5 is almost too hot to touch...I've never had a problem painting engine covers before, but none of my previous cars have gotten quite this toasty...
nogears909
Car: 2008 Niagra Grey Coupe 2.5S CVT
ESP wrote:Just wondering how hot the 3.5 gets?I considered painting mine, but after only a few minutes of regular driving the engine cover on my 2.5 is almost too hot to touch...I've never had a problem painting engine covers before, but none of my previous cars have gotten quite this toasty...
i drove mine for about an hour, popped the hood, and put my whole hand on the cover and it wasnt that bad
rjdmmfl1
MBclutch ... thanks for the advice on how to properly paint the engine cover...
I finally got my new engine cover, and was able to paint it over the last couple of days...
I was able to get perfect Nissan Radiant Silver paint in aerosol form from these guys...
http://www.automotivetouchup.com/spray_paint.asp
I'll have more pics up later... but here's a few... thanks again MB!!
Modified by rjdmmfl1 at 12:52 PM 7/19/2008
Modified by rjdmmfl1 at 9:25 PM 7/19/2008
AltiCoupeFan
Car: Altima Coupe
Hey, look'en great. I gotta put that on my list.
AltiCoupeFan
Car: Altima Coupe
08altima35 wrote:looks good. , but what's up with the woodgrain engine?
