Pics of my new G35 Coupe!
BainyG35
Car: Black 2003 Infiniti G35 Coupe.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
Nice. Welcome to the family. Looks like its in great condition. You let us know when you want to make that car more fun to drive :D
BainyG35
Haha im getting an intake this week for now. plan on getting rims borla exhaust vortec supercharger. and do the little stuff too
tollboothwilley
if you are getting a SC then don't spend money on an intake. You won't use them together and it will just be a waste of $$.
You should get a plenum spacer (i'm actually in the process of making one - hopefully can get it done much cheaper that other options currently available)
Exhaust will be helpful with the supercharger - headers can especially help. Replacing the stock cats with HFC or Test pipes is probably one of the best mods you can do on this vehicle for $$/HP ratio.
BainyG35
The Sc will be this summer so intake for now wouldn't be bad.
What will a spacer do?
tollboothwilley
Intake will be a waste...especially since you won't pic up very much power without a tune. Save the $150-300.
A spacer goes between the upper and lower plenums increasing air volume. It is generally known to be the best mod $$/HP.
Take a look here:
http://www.motordyneengineering.com/ind ... 096724f667
there are other options than this one - Mine is 3/8" thick.
g35boy
Car: 2008 Infiniti G35 Sedan
Do they have one for a 2008 infiniti g35? This seems like this will produce more power then a intake n it's cheaper
biggie
g35boy wrote:Do they have one for a 2008 infiniti g35? This seems like this will produce more power then a intake n it's cheaper
The issue that spacer corrects was corrected on later VQ engines, so isn't need/useful on the '08.
g35boy
And also I'm having a hard time finding a super charger for a 08 g35
tollboothwilley
http://www.stillen.com
http://www.vortechsuperchargers.com/
http://www.phase2motortrend.com
http://www.conceptzperformance.com
there are lots of places to look
I'm not sure if they have a specific stillen SC kit for the 2007/2008 G35 though
eellie
Car: 1996 Nissan 300ZX Commemorative Edition
2010 Nissan 370Z
car is hot!
BainyG35
Thanks. And toll what size do you recommened getting? I want to keep the engine cover on though, and produces a good amount of hp.
BainyG35
http://www.advancespeedshop.com/skunk2- ... -7410.html
Should i get this?
If not what size and brand would be best? They have motordynes cheaper on ebay too
BainyG35
Anyone?
joe603
Car: 2014 Durango R/T
Welcome to NICO!
My previous car was a 2005 G35 coupe...with some mods. Here's what I would recommend:
It sounds like you want an intake now and possibly get a supercharger later. I was the same way (never got to the supercharger though). Anyway, there is an inexpensive option with a JWT PopCharger and a Z-tube. It looks decent and will not cost as much as other intakes.
http://www.g35parts.com/G35-JWT-Pop-Cha ... rgerco.htm
For the plenum, I'd stick with MotorDyne. The quality of parts are much better. 5/16 will work well for mid-range RPMs.
http://www.motordyneengineering.com/ind ... 2390112623
Finally, for the exhaust, I'd go with either Stillen or Greddy.
http://www.g35parts.com/Infiniti-G35-Co ... s-s/61.htm
xjaywalker
Car: Orange County, CA
06 G35 Sport Coupe Prem NAV
Welcome to NICO Bainy.......
These guys are right.....you really do not get a lot of HP from a CAI....just sounds better. A waste of $$ I did what they suggeted and installed the motordyne 5/16 spacer....a little over $200.
Enjoy yur ride!
SavG35
Car: 2004 Infiniti G35 Coupe
Upgrade with a spacer or a new bigger plenum like the Kinetix. Also look into the stillen UD pulleys and a light weight flywheel.
tollboothwilley
I am currently running a 3/8" spacer. I started out with a 5/8" - cover doesn't fit well but more importantly there are gains from using smaller spacers.
I'd recommend a 5/16, 3/8, or 1/2
3/8 is the perfect size for HP/TQ gains.
i noticed cooler temps when i used the 5/8" composite plastic vs the motordyne aluminum. This is the reason I make mine out of 3/8" composite.
