pics of my new factory 16s
1qckser
Car: my wife, daughter, q45T,G20T,SE-R
The tires are 255/50/16 in the rear, and 245/50/16 in the front, I love the stance, the car handles sweet and looks bad azz, next week new Tokico blues and Qships energy suspension bushings.http://www.imagestation.com/album/?id=4289455153
Wow! She looks great!
She's Quella's older sister! Same tires, wheels, paint, spoiler...
Hubba hubba!!!
1qckser
Thanks AZ, I fell in love when I seen yours so I had to go for it, you had the look I like, subtle yet mean lookn, I keep going to the front door to check it out, only problem is its raining so no testing yet,
1qckser
How do you like the exhaust? I redoing it soon.
I like the straight-cut pipes - What size are they? I don't see the big-arse muffler - What have you changed on it?
1qckser
I ran 2 1/4 pipe from the factory resonators, I ceramic coated it when I realized you could see it from behind, I then used 2 bullet style resonators into 2 3.5 inch resonated APC tips, its got a nice smooth sound, almost like a quite Z06 nice n deep. Did you do yours yet? QSHIP is goin nuts on his car, he just did some good mods, also your wheels look great on his car>
Hmmmm.... Gimme some more info on the resonators and the tips.
You didn't notice any real performance changes, I take it?
Tell Chad I don't wanna hear JACK about his car 'til we see some pics! :D
docsmile71
DAYYYYYUUUUUUUUMMMMMM!!!! That is one nice looking Q. Love the exhaust.
So you have no muffler? Just resonators that run into straight pipes?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
GOLDEN!!!! I like the wheels, although I would have gotten them chromed.... But that is just me..........
90Q45blue
Car: 2006 Honda Accord EX-L
I actually don't like the chrome look as well (personal preference). Kudos to you on a great-looking Q!
Nick
elwesso
2007 BMW M Coupe
Truely!!!
1qckser
Thanks guys, I like the chrome but the way I drive it would just attract more attention than I need :D My exhaust I think added some in the higher rpm range, im just using the factory resonators and the aftermarket ones are a bullet style with a smoothe perforated core, I went with these because a Q with straight pipe sounds like a ZR1 with an exhaust leak yuuuk, the resonated tips are just icing on the cake, the care has a nice mellow real deep sound under a loud, but lay into the throttle and bring it up into the rpms and it sounds like a formula 1 car, I tucked the resonators up so they couldnt be seen from the rear, the pipe and the resonators are actually tacked together, thanks again guys for the nice words, everytime I look at the car I cry because I only paid $1500 for it and a lot of the work was done prior to me purchasing it, by the way AZ im gonna see QSHIP tommorow so maybe I can get some pics of his car now, he just did a great deal of work and the car performs awesome. Thanks:)
Q451990
1qckser wrote:The tires are 255/50/16 in the rear, and 245/50/16 in the front
Why did you use the 245s in the front? Just curious since I have four 255s in my garage waiting to go on those same rims. From everything I've heard and can see, they should fit and I wanted them to be the same since I cross rotate them at each oil change.
Heath
1qckser
I had seen this setup before on a 94 Q, he did it with 17s and I liked the way it looked, I know Dennis is gonna yell at me but I just couldnt resist doing it, if you see it in person you will understand, kinda looks like the stance of a 740I plus I had a huge fender well gap to get under control, I know I will regret doing it when its time to rotate but they are not to expensive so I will deal with it, 255s all around will look awesome, please post pics when you have it done.:)
Q451990
Hopefully I'll be taking pics soon... I have "Q2" on jack stands in my garage with more stuff off of it than on at this point. Took the brake calipers off for a good cleaning before installing the new Stillen rotors (thanks Joe!), SS flex lines, and trying out my new dial indicator for indexing them.
Heath
1qckser
Wow, your doin the stuff I need to do, have you tried the ss lines on your other Q? What kinda pads are you using?
Q451990
Never tried the SS lines before - just thought 13 year old lines should be replaced with something, and these weren't much more expensive. Got them from TechnaFit.
I'm just using OEM pads. I tried aftermarket once and had bad glazing and noise. I've heard good things about the Metal Masters - I think Dennis uses them on the back and OEM on the front (or vice versa, can't remember for sure).
Heath
