Pics of my KA-T for now
574-240sx
Car: Nissans, Toyotas, Subaru
I finished almost 2 months ago and finally took some pics a few days ago. I's set for right now. I have everything thing setup and it runs just like factory but better. I plan on doing some more this winter. So on with the pics.
mounting the 9x21x3 intercooler
jgs manifold mounted with a copper exhuast manifold gasket
Turbo with down pipe, its accually wrapped in heat wrap today
All done
All done side shot
All done front view
Thanks for taking a look at my KA-T. Nick
Jookmasta
any issues with the mounting of ur intercooler? also is that a plastic pipe that u used for ur intake pipe?
574-240sx
Jookmasta wrote:any issues with the mounting of ur intercooler? also is that a plastic pipe that u used for ur intake pipe?
I had to cut the bumper a little to get the intercooler to mount flust with the bumper. The mounts for the intercooler are spaced 1 1/2 inches lower than the radiator support. As for the intake it is 3inch hard rubber sewer stuff I picked up from a local hardware store. It works just fine for now. Nick
Silvia007
Car: 93 Nissan 240SX SE Fastback
Is that a stock KA or is it built? Anyway, man that's nice, I see you cut your bumber support. Too big a intercooler huh?
574-240sx
Silvia007 wrote:Is that a stock KA or is it built? Anyway, man that's nice, I see you cut your bumber support. Too big a intercooler huh?
I cant imagine mounting anything bigger or you would have to do without the bumper support. Its a little big but I made it fit.
gabossie
Car: Your mom
Looks good. What boost are you running?
574-240sx
gabossie wrote:Looks good. What boost are you running?
Only 7psi for now. I will hopefully run it at the track this weekend.
Structure240sx
got any more pics of the entire car? that front view looks really sweet
coupe4me
Car: '89 240sx coupe and '02 Sentra Se-r V spec
I have a couple of questions, did you buy a kit or did you piece it together yourself? What engine managment system did you use? is it just the SAFCII? no ecu tunning? Also what type of GM electric fan did you get to work? I want to turbo my Ka and need all the info that I can get. I appreciate any help you can send this way. Nice job by the way your car is Super Clean, I would like to see more pictures of it too.
daniel240
Car: cars/motocross
yea your car looks sweet. i love the color.
574-240sx
coupe4me wrote:I have a couple of questions, did you buy a kit or did you piece it together yourself? What engine managment system did you use? is it just the SAFCII? no ecu tunning? Also what type of GM electric fan did you get to work? I want to turbo my Ka and need all the info that I can get. I appreciate any help you can send this way. Nice job by the way your car is Super Clean, I would like to see more pictures of it too.
Thanks for the compliments, nobody had ever thought much of my car. I pieced my kit together because I didn't like what was offered. I used the jgs manifold. and SAFCII and I tunned it with the wideband, I also used stock SR injectors. I knocked back timing a bit too, for the time being. The ecu is the stock auto ecu, I did the 5-speed swap. I rather start with auto and convert them to manuals. The GM electric fan is off an oldsmoblile, don't remember the model but it came with the shroud. I will get some pics up later, yes its stock paint. Thanks. Nick
574-240sx
More pics
Ace 2.0
Car: z32 2+2,1987 CRX si
looks really good. i would weld a steel bar accross the bumper support though.
Structure240sx
definitly looks great
Snail Tuning
Car: 1991 Honda CRX
project looks great
boost infested
Car: cars, chicks, food, and .....
finally, another kat s13! nice ride!
