Pics of mounted alternator
imprecation
Car: 93 RPS13
Can someone please post pics of their alternator, particularly the bracket. I received a bracket for the CA and an alternator but I think the bracket is the wrong one because I can't see a place anywhere to bolt it onto the block or manifolds.
boost_boy
Alternator bracket has 2 bolt holes in it. These two holes are to be mounted onto the water pump and bolted down. The hole on the adjustment bolt is to be bolted to the alternator and that should square you away.
Dee
slownslurious
there is downloadable CA18det FSM available at that zylon site or whatever, just do a search I'm sure it will turn up, and the diagrams there should guide you through it.
float_6969
The DL to the FSM is in the FAQ.
imprecation
Car: 93 RPS13
I got the FSM i just couldn't find the bracket. With boost_boy's advice though I went downstairs, looked at it for half a minute then kicked myself for not seeing it before. Thanks for all the quick replies. The Zeroyon FSM isn't as good as the one in these forums.
boost_boy
imprecation wrote:I got the FSM i just couldn't find the bracket. With boost_boy's advice though I went downstairs, looked at it for half a minute then kicked myself for not seeing it before. Thanks for all the quick replies. The Zeroyon FSM isn't as good as the one in these forums.
It happens to the best of us .
Dee
