crakin wrote:Excuse me but I've never heard of a recirculated BOV. Can someone please explain the advantages and/or disadvantages.....Thank you.
Alright i have done both
Recirculated with the Greddy Type S
and
not Circulated with the Greddy Type RS
you recirculate becuase when you shift the turbo slows down and the required amount of air at the idle point is reduced but you still have that huge slug of fuel going into the cylinders so you need that amount of air to make sure you have the right air to fuel ratio so it will go into idling right and it wont try to kill itslef
my car ran fine when i recirculated
but once i uncirculated it use to idle alittle funky untill the air to fuel ratio evened out and it would try to kill itself at idle because it was lacking that little bit of air it need for the air to fuel ratio to be correct
i have noticed frrom personal expirence that this only happens when you are coming to an adrupt stop
but when you slow down properly and dont come speeding into stop lights the air to fuel ratio will stay smooth through the transtion of gears all the way to when you have stopped completely
people have told me for best result RECIRCULATE
but i like my BOV alittle louder so i have opted not to reciculate
and i have been told through tuning i can fix that little air fuel ratio problem
if i am wrong about any this please correct me (i have only had a year expirence with the SR motor) and there are poeple out there with more knowledge then me
