pics of finished SR
xsublimefrekx
Car: 1991 s13. SR20det, 1998 s14
The car was tuned at 10 psi. and made 300 h.p. The car was finished about a month ago but i just got around to taking pictures.
vutony
lookin good, wats ur mod list
Modified by vutony at 7:13 PM 10/17/2006
Morph
Car: 91 Sr Powered Coupe
Sorry bud but you get -50 for not including a mod list.
xsublimefrekx
JE 9:1 pistonsEagle RodsSp 850cc injectorsJWT C1 i/o camsFerrea Dual Valve SpringGreddy Adj. Cam GearsGreddy CatchcanExedy FlywheelACT Heavy duty 6puck ClutchHKS Type S intercoolerPeakBoost ManifoldHKS Super Sequential BOVTial 44m WastegateGT35r TurboApexi Intakez32 MAF240sxMotoring 3" downpipeInvidia 3" ExhaustAEM EMSand im sure i am missing some things.
Modified by xsublimefrekx at 7:47 PM 10/17/2006
Blown240sx
Car: 1996 240sx
Looks almost like my setup. Cept my motor isnt built. But you did the samething I was going to do. 9:1 compression. Spools the turbo faster and makes better power on lower boost.
xsublimefrekx
yeah i really like the way the 9:1 works.
adam-gtX
looks nice and nice numbers also.
wildacexxx
Car: 2002 Q45 nav sport
when is full boost on that monster?
xsublimefrekx
i get full boost around 4300 or 4500.
Blown240sx
Car: 1996 240sx
Yea Im running a Ported GT3071R get full boost at 3800-4000 rpm on stock compression.
da40
Car: 1995 SE 240sx
NICE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
xsublimefrekx
thanks for all the comments.
g-man
Car: 1991 240SX
Did you make that mc heat shield or did you buy it?
xsublimefrekx
i made it. I need something real quick because i burned 2 master cylinder reservoirs in 1 week. I just had some metal laying around and bent it with a pipe and drilled some holes. It worked for the most part. When i get some time i will probally make a nicer one.
sl87
Car: nissan 240sx
very nice setup.
xsublimefrekx
When i get some extra money i want to bring it and get it retuned for 18 psi. and see how much power i make.
sil8y-X
Car: 1989 Nissan 240sx Hatch
Nice build man, you're car is going to go crazy on 18lbs. Keep us posted.
xsublimefrekx
The first run on the dyno it made 300 hp at 26 psi. untuned. I had some problems with the boost controler so thats why it boosted to 26 psi.
sil8y-X
It's amazing what a little tuning will do.
xsublimefrekx
it really is. Tuning will make it a totaly different car
