95-J30tt »
https://forums.nicoclub.com/95-j30tt-u40286.html
Mon Oct 16, 2006 11:34 am
thank you NismoChi, i need pictures of
the driver side fire wall, and the wheel well from the engine room side,
also if you can show me where the accelerator wire is coming out from, the engine mounts themselves and where they go.........
well i'm doing a manual tt swap in three weeks, basically want to install the clutch pedal and clutch master cylinder and booster with the clutch vaccume lines and tank and thinking of where and how to install them
if you have pictures of the transmission room with the transmission off, i would really appreciate that.....
from the picture that you posted earlier, you seem to have disconnected the ac compressor from the block and then removed the engine, was that a hard task (hitting or pinching AC lines while taking out the engine)???
in the service manual it says that the cross member has to go out before the engine and transmission can come out, was that true in your case???
thank you in advance, i would really appreciate your help, e-mail me the pictures if you can, i'll be very thankfull
