pics of egt probe installed on rb25?
branmr2
Car: 91 mr2 na/jdm 3sgte swap/ 95 240 w rb25 swap
I bought a 95 240 with a rb25 swap already done, the other day i was re doing some stuff under the hood i did'nt like and noticed that the egt probe was installed in the downpipe after the turbo. Unless im mistaken is'nt that supposted to be before the turbo in the manifold? If anyone has any pics of there egt probe installed in a rb25 stock manifold it would be great. Im gonna move the probe sometime and would like to know exactly where and at what angle other peoples probes are mounted.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Man! Why didn't you post this three days ago when I had my manifold off?! haha jk. I will try to get a picture of the plug where I drilled and tapped the manifold. Just happens that where I drilled the hole, the damn turbo coolant feed line interferes.
Basically, it was 2-inches from the face of the flange on runner #6. Angle does not matter as long as the location of the sensing part is located in the middle of the runner and not grounding out to the other side.
branmr2
thanks, I will be looking for the pics!
