slipnfall »
https://forums.nicoclub.com/slipnfall-u4227.html
Wed Jan 04, 2006 4:55 pm
thx again!
I was getting anxious towards the end, so I didn't take as many pictures. I used some left-over dynomat on the adaptor plates, and surrounding metal. BTW I saw you can get two 10"x10" sheets of the dynomatt extreme on ebay for $5+$4 S&H. I'm glad to see the prices have dropped on that stuff, it was overpriced the last time I looked.
Anyways, here are some tips for mounting the tweeter:
First, pick a spot! I chose to start with the driver's door, only because that's the one that's going to matter the most to you. Sit in the car, with the door closed, and mark a spot on the door panel(sharpie works).
Pull the door panel off, and take a closer look at where you want it to go. I moved my location slightly in an attempt to find the flattest spot possible: you wouldn't want to mount the tweeter on a significantly-rounded surface.
Take your tweeter, and use it to draw a circle onto the vinyl door panel with a fine-point sharpie(or whatever). Carefully cut as deep as you can into the vinyl with an exacto or razor blade. Peel the vinyl circle off and the padding behind it *before* trying to cut through the carboard/wood composite behind it. This will keep the vinyl from potentially tearing.
For the next hole I used the router-style attachment on the dremel. Although it was pretty dulled up from the lexan, it cut through this stuff like butter. Check the hole size, and slowly open it up untill the tweeter fit through just-so.
Test fit the tweet', and check that it will screw tight enough to make itself flush. If not, simply remove some of the foam backing from underneith the edges of the vinyl. See the below pic; the are with the foam remove(and the one directly across from it, out of view), will allow the mounting 'flange' to sit lower, filling in a gap that was 90* away from it in either direction... hope that makes sense. This isn't always neccessary, so tighten your tweeter mount locking ring as much as needed to make it flush.
