Pics of 20" 10.5 +25 wheels on the back with stock ride height?
neo_rambo
I have a 2013 stock ride height
I did the wheel calculator https://www.wheel-size.com/calc/and I got
  • wheel well clearance: 2.75"
    rear suspension clearance: 3"
    I can't get the damn Fender Clearance measurement
I've tried using a ruler and I can't get the accuracy. I'm trying to see what the poke is on a 20x10.5 with 25 offset with stock height for now. I know with suspension I can lower it and have it tuck in but in the meantime I want to see what it looks like with stock height. Any pictures would really help or if anyone knows the fender clearance sport with model wheels would help too.
DoN_BLaZe34
Car: 2007 M45 Sport - Sold
2006 FX45 - Traded
2014 Q70S 5.6 - Sold
2017 Q70L 5.6 - Current
Assuming you have the sport 20's those wheels will stick out roughly 33mm if you were using a 275/35/20 tire.
This site provides fender clearance:
http://www.rimsntires.com/specspro.jsp
Don't have a picture but hope that helps.
neo_rambo
DoN_BLaZe34 wrote:
Wed Jun 06, 2018 7:32 pm
Thanks DoN_BlaZe34, Is it 33mm from the edge of the existing Sport rim or from the center of the wheel? I want the wheel to look flush and I'm trying to figure it before I spend $$$ on wheels
Purenv
Car: 2012 Infiniti M37x stormfront gray
10.5" will barely fit with a +40
see: https://www.wheel-size.com/calc/?wheel1 ... 0mm&sr=0mm
neo_rambo
Purenv wrote:
Thu Jun 07, 2018 4:17 pm
The wheels I'm looking at are +25 not 40. I just want to see what that kind of wheel looks like on a standard non-lowered m37/56 if anyone has any pics it would be appreciated.
Malbec 56 Beast
Car: 2013 Infiniti M66xS Totaled 4/11/20
What's next???
2010 Subaru Legacy
1983 Porsche 928 S Euro (Sold) 2/17/20
That is the exact dimensions of the gtr wheels and they stick out way to much.
Good luck and go with another offset to properly fit.
Andy
DoN_BLaZe34
2006 FX45 - Traded
neo_rambo wrote:
Thu Jun 07, 2018 6:53 am
Center of the wheel. That offset will not be flush with your car, the wheel will stick out past the fender.
You're going to have a difficult time finding anyone using those wheel specs at stock height given it sticks out past the fender. I run those specs but am lowered and have to run 255's just to make them fit.
neo_rambo
So what would you recommend for the rear? 20x10 +30?
Malbec 56 Beast
What's next???
2010 Subaru Legacy
If you go to carid and input your car info they have a lot of choices. If you don't put the awd (x) it'll give you stagnated fitment, if your car is a sport they have that match.
You should be able to see what will fit and what doesn't.
Good luck
Andy
