start small and go slow.... use sense... if your car has almost no fender gap you need to start really slow and slow.... a baseball bat has a good range of size to work with. Also a heat gun helps keep the paint from chipping/crackingblacktop sr20kid wrote:diy 2 people
1 stick flashlight/bar/crossbar/item of your choice as far in between the tire and the fender as you can
1 person slowly drive forward/backward while the other person guides it through the rotation
if necessary while you are doing this process and need a bigger roll push/pull the flashlight/bar/crossbar/item of your choice as it you as you are guiding it through the rotation.
dont exactly get what your saying here..your saying use a "half phonebook" sized paperback and fold it?spencer240sx wrote:i always use a chition manual or a news paper folded over ...Start by jacking car up with rim on, put paper on top of tire between fender then slowly lower car then lift car back up move paper a little then repeat over and over agian till u get it were u need it If want more pull add more folds...
i think he means a chilton ( not folded.... as far as i know they are hard back lol.. ) or a newspaper folded up...E7-S14 wrote:
