jleon_17 »
https://forums.nicoclub.com/jleon-17-u143497.html
Thu Oct 01, 2009 4:03 pm
Is not the battery, i tested it with my own tester, and the guys at autozone tested it and charged, the battery is fine, the ground is fine, no corrosion good contacts, i rang the relays and they came up fine, the only thing i need is someone that has a wiring diagram so i can see the full circuit and tested it all before i teardown the dash. So IS NOT THE BATTERY. I havent checked the starter yet, but that will be my next step if i dont find the wiring diagram.
