Pickup coil questions
Chingon
Car: 1991 and 1992 hatchbacks
Do you guys know if the ignition coil is the same as the pick-up coil? and if not is the pick-up coil the same as the main coil? I need to know what to replace.
I had my car computer diagnosed (92 hatchback ka engine 150k miles) and the technician said that the subtle little explosions that can be felt above 2krpms are caused by the pick-up coil, what do you guys think about this?
Chingon
anybody?
p00t
the entire ignition system is:
Battery/alternator- - - - -to- - - - - -Ignition Coil- - - - -to- - - - - -Distributor- - - - -to- - - - - -Spark Plugs
Im guessing he ment the Ignition Coil, theres no other coils or systems along the ignition path :confused:
Chingon
Its supposed to be inside the distributor.something like this:http://www.fierofocus.com/arti....html
