always plot a point for redline. you'll easily rev past 5500 when you're accelerating, so it's best to know what your compressor will do in the higher rpms. doing this will put both islands between 3500 and 6900, so then it comes down to which compressor stays more efficient through a larger rpm range. this is where the 50 trim shines.fiznat wrote:*note for both graphs, each line has 2 hash marks on it. The first marks out 3500rpm, the second 5500rpm. I figure this is a good way to scale it because that is where most daily driving/accelerating happens.
Nathan and I were both kinda dissapointed on how these turbos are somewhat less than ideal for the given flow rates. Ideally, we'd like to see the main "island" of efficiency right up in between those hash marks, but in both cases the turbos seem to be more suited for higher RPMs (or, more specifically, higher flow rates).
Anyone have any input on this?
demcj wrote:the 60 trim is not a bad compressor if you don't try mating it to a t3 turbine. it's surge limit is it's downfall, so you'll need a t4 turbine to make sure it doesn't spool too fast. the 50 trim on the other hand is almost impossible to surge. it's nice to be able to spool 15psi at 3000rpms and still be at 70% efficiency.
-demetrius
Nathan wrote:
As you can see I graphed for 10, 15, and 20psi just for everyones benefit. The hash marks are also as follows:1st from left: 3000rpms2nd from left: 5000rpms3rd from left: 6500rpms
It should also be noted that this map is missing the efficiency percentages at each island, I would assume the center island is >70%, probably 74 or something. The super-60 isn't really ideal for a KA, but it seems to do okish at 10psi. Thats not to say you have a BAD turbo though, if your happy and the car does what you want and does it reliably then it's all good in my mind![]()
boost infested wrote:here is a link to the "super" t04e series.
http://www.turbocalculator.com/garrett.html
those super series compressor maps are completely jacked up. i've seen some better ones somewhere. i'll post them if i find them.Nathan wrote:Hmmm, they dont look too "super" to me, the normal 50 trim is a good bit more efficient at 20psi and 6500rpms than the Super 50 is and even marginally more efficient at 15psi, 5000rpms.
demcj wrote:the numbers for the t3 super 60 are exactly the same as the t3 60 trim. lemme hear you talk smack now.
-demetrius
MarkEmark wrote:You're right though Demetrius--the graphs look exactly the same. So why would they distinguish between the T3 60 trim and the T3 super 60? If anything, I like how my turbo has the name super in it. It's not just a T3 turbo. It's a SUPER t3 turbo :ylsuper
look very closely at both compressor maps. the super 60 has a slightly broader efficiency range than the 60 trim. the difference is easy to spot if you follow the line for the surge limit for both maps. someone on a saturn forum told me that the super 60 is slightly more efficient (by like 1-2%, but he couldn't prove it), but it's still too small for the KA.
I'm confused who the "you" is in your response--is the fact that the T3 super 60 and the T3 60 trim are exactly the same supposed to be bad?!? Sorry, I'm really burned out---I had a 2 hour calculus exam at 730 this morning![]()
i'm picking on you. go to sleep.
-demetrius
C-Kwik wrote:Pedro's pic is along the lines of what I'm talking about but imagine the andgled line extending further up and about the same angle and intersecting the other two horizontal lines as well. That would be more realistic of what it would like like.
