Picking my injector size and tune.
Nicksemianiw
Car: JDM 89 Silvia K's
Mods will be a S14 T28 (GT28R) and the normal bolt on's. My goals are around 280-300whp will a set of 444's and a SFAC'II with a dyno tune be good enough for this or will I need 550's? and like E-rom? I only want 300whp or less nothing crazzy.
themadscientist
550s, a bigger pump and a ROM tune. Might want to think about a bigger air flow meter as well.
Nicksemianiw
the AFM is a dead give away same with the Fuel pump, but I am just wondering if I need 444's or 550's with a SAFC'II and get the safc'II tuned on a dyno for 280-300 whp or if I need a whole stand alone.
themadscientist
For something this level a good ROM tuned stock ECU would get it done.
NUT-CSE
Car: 1988 Nissan Exa
550's would be best to give you a lil breathing space, good for around 350whp
As for the ECU, id go for a good standalone with MAP sensor
Two-Fortee
Car: 180sx.
NUT-CSE wrote:550's would be best to give you a lil breathing space, good for around 350whp
Id only suggest that if hes not on a budget ^
ROM tune is your best bet if your on a budget.
yourmomsrps13
Car: Drifting ruined my life since 03' 240sx CA18DET
what do the 390s max out at? I just got a T28R
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
They are 370s, and I would not give them any more than 220hp worth of credit.
OP, you'll want some bigger injectors. 550 will work well. You might want to consider a bigger turbo as well. That little t28 will be balls-to-the-wall maxed out at 300hp. Might not ever see 300whp. I have a GT2860R and have a hard time imagining it pushing more than 260-270whp at 18-20psi. Any more than that and it'll be way out of its efficiency range.
yourmomsrps13
wow i did say 390 huh i gotta stop looking at DSM injectors while posting in here
NUT-CSE
I ran the 370's with a adjustable FPR and bosch 040 pump and it made 248whp and they had to abort the dyno run as they were all out of flow at 5500rpm and leaned out quite badly.
jey_253
Car: 1990 S13 Silvia Conversion Rb25det
Always go bigger than your goals, u can always turn down bigger injectors. You dnt have to be crazy like me and purchase 1000cc injectors though...unless u really like boost :}
