could be. I bought it on Friday the 13thZL8NING wrote:Gremlins!!
LOl. This is the first Nissan I have ever owned. I was sitting around last week saying to myself, "self, I don't have enough stress and agony in my life so I should probably remedy that" So I figured buying a 25year old turbo import would solve that problemThisIsSparTTa wrote:You went from buying a 300ZX to changing injectors the next day? Have you owned a 300ZX before? If not I'm impressed by your drive, and your ability to search things out and pick up on new things.
FYI, you should figure out if you have new or old style injectors. If they are old style, you should consider replacing before they fail and cause more headaches. http://z32.wikispaces.com/Fuel+Injector
Thanks for the welcome. I'll have to check out concept z. I've been all over z1, and even have a box from them sitting on my table, lol. All new connectors for coils and injectors. There was some service records with the car. The timing belt was changed at a Nissan dealer 3000 miles ago (however that was 2 years ago!) $1600+ ouch!! This car already reminds me of the 03-04 cobra's I've had with the "since I'm already doing xxxx I might as well do this xxxx". LOL. I smell a money pitThisIsSparTTa wrote:Awesome man, well whatever you can't find on search we'll try to fill in the rest.
So yea, some things to consider: Ethanol in the gas now destroys the old injectors and is a super common problem. Most people either go to the new 370CC or up to the 740CC if they want to leave room for future mods. Staying with the 370CC, you could just change the injectors and the connectors (with an adapter kit). Going bigger would require a socketed ECU and a base tune from a shop like SpecialtyZ. Once you start down that slippery slope, there's other fun tasks to do too, like deleting the extra coolant lines for the throttle bodies. If you're already down at the injectors, I would recommend at least replacing the intake valve cover gaskets, because its easy enough and a cheap part. You can also do the exhaust valve covers, but its liquid gasket and a HUGE PITA with the engine in.
You should also consider a 120k kit if you don't know the last time the timing belt was changed. Timing belt breaking = interference = dead engine. It's good maintenance to do.
Anyways, welcome to the club. I'll let you figure it all out, here's a couple of info links, and links to the 2 most popular stores that stock our parts, if you weren't already on top of it:
http://z32.wikispaces.com/Intake+Manifold+Removal
http://conceptzperformance.com/
http://www.z1motorsports.com/
That's exactly what I'm going to do with this car. try to sort out all the usual issues and have some fun with it. I'm going to do the fuel pressure test on it, change the fuel filter, just got two new bosch o2 sensors delivered today, and am going to do some sort of boost gauge. The stock one only reads around 7 psi at wot. Not sure if not making full boost, or the gauge is just off that much. I'm betting the cat's look like poop with the miles that are on it. Thinking of removing them also as I live in a no emissions county.ThisIsSparTTa wrote:You should be good on the timing belt then. Technically its 60k miles or 48 months. And yea, that fee doesn't really surprise me. The kit isn't cheap, and it does take a few hours. Probably a bit higher coming from the dealer, but still.
And yea, its a slippery slope indeed. However, most of the recommendations you're going to be getting are from us guys that did just deal with problem 1 up front, and then ended up having to deal with problems 2 and 3 anyways. I'm very guilty of this. However, I do know exactly what I'd do to a new unknown car now to go straight to reliable and running solid!
If its in safety mode how do I get it back out?ThisIsSparTTa wrote:I've seen a couple set of test pipes come up on the Facebook group recently for getting rid of your cats: https://www.facebook.com/groups/227766473927972/
Sounds like you're in safety boost, you should pull your engine codes if you haven't already. Most common culprit is the knock sensor. And, since you're on the good path, you can pull the codes at the ECU now, but I would highly recommend grabbing a $30 Consult to USB adapter from eBay and using free software like ECUTalk that not only lets you get codes without pulling ECU, but lets you read all the sensor values, which can be really helpful in troubleshooting. There's also $100 ConZult software which does some WILD stuff too, but not necessary for me.
http://z32.wikispaces.com/ECU+Diagnostics
http://z32.wikispaces.com/Safety+Mode
I didnt have that code when I last checked but I can check again. I have a boost gauge on the way so I can verify boost. So if I understand there is no procedure for removing car from safety mode? In the camaros if you get kicked into low octane mode you have to pull a couple fuses to reset the fuel maps.ThisIsSparTTa wrote:If its for the knock code (34), you will need to do a knock sensor relocation. Technically you can put a resistance on their, but its not recommended. The knock sensor isn't accessible without taking half the engine apart. So, instead there's a few good points on the plenum to mount it to, and at least you're getting some protection from it, and you'll clear the code. If you're ever tearing your engine down, then you can get at it and put a new one in the correct place.
Also, Z1 and CZP sell a modified knock sensor sub-harness thats more resistant to the problems of the OEM, which will help prevent more headaches in the future.
You sir, are a wealth of information! Thanks!! Okay I installed the aftermarket boost gauge tonight and I can confirm that the car is only making 5-6 psi. I haven't had time to recheck the ecu for codes, but I will when I get a chance. Read that boost jet link you gave. I will have to poke around under the hood and try and locate those solenoids. Seems like there was a good amount of overengineering on these cars. I'd like to do as many "deletes" as possible to clear some of this clutter up. Also my Hicas light is on and it feels and sounds like the power steering pump is on the way out....quickly. One step forward and two steps backThisIsSparTTa wrote:As far as I'm aware the only procedure would be to correct the issue, and then it will remove the code and safety mapping itself.
One other thought if you're not getting codes from your ECU and still running low boost is that the stock TT setup uses boost jets in the vacuum lines going to the wastegates. It's possible that someone replaced some vacuum lines and missed the boost jets. I pretty much did when I was reworking my engine. I have my stock boost jets somewhere if you need them. This is all better explained here: http://www.thumper300zx.com/z32/factory ... y_jets.htm
