picked up a Weber!!need sum help!!!
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
bracktheron720
Car: 1984 720 with 1980 datsun front end,1972 yamaha cs3
hey everybody havnt been around in a while..well i just picked up a weber 34 34 off craigs list for a good deal..just gotta order an adapter plate to get it all bolted up..what im wondering about is how the hell do i get the throttle cable hooked up?????? the carb was on a 22r and looks to have a universal type linkage on it.....if Pezi or any of the other guys runnin webers comes across this i could really use sum pics of how youv got everything hooked up!!! Please help a fellow datsun lover out!!! :chuckle: oh and i know its not a real weber its a solex so i dont need all the crap about that i do know that much...lol and im just assuming but will the adapter for any dg series carb to z24 manifold on the weber site b the one i need??
PEZi
i would call to make sure the adapter is the same for all of them... but i'm pretty sure you're good
as far as the linkage, it looks a little different from mine, so i'm not really sure without a better look at it
bracktheron720
Hey pezi thanks man I think IV got the adapter figured out..what I could really use is a couple good pics of how UV got ur throttle cable attached..
bracktheron720
can anybody help me out?? I know theres a bunch of people runnin webers out there....can anybody take me a couple pics of how there throttle cables are attatched and send them my way????
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
IIRC throttle cable comes from drivers firewall across the back of the bay and connects behind the weber by the throttle.
The wire of the solenoid comes of the passenger side.
PEZi
yeah... went through my pics.. .don't have any
i can snap some though
bracktheron720
That would b Rad! Im either gunna just cut the very. End of the cable off and get an end with a set screw that I can bolt to cam thing the throttle hooks to or IV got the stock part the cable hooks to and it fits on the Weber so I mite try to rig it up..I hope that makes since
.lol ill get sum pics up of what I'm talking about.. what I really need is a good pic of how the cable attaches To the Carb...... thanks everybody!!!!
MetalFab
Car: 1985 720 4x4 reg cab flatbed.
By all means stay away from the setup where you shove a wire into a collet and hold it only with a set screw. It'll fall apart at the worst possible times (that would be just about anytime eh? lol) I've run into no end of trouble with it. Can't find a pic of how visio hooked up his 4 bbl but it was pretty trick >.< Not much help but I'll try to roust him out and get a pic.
synack7350
Car: nissan '83 720 king cab pickup 2wd 2.4L Z24
yeah that dealy there is for hooking up the collet style thingy mabob. mine came with the cable guide style for using the lead t at the end. I just had to flip it upside down to work. that dealy comes off though and can be replaced with the cable guided style you'd just have to find a part number. I'll take some pics in the morning.
synack7350
but while we're on topic the weber auto choke. just supply 12v and it should open right, I'm assuming its grounded internally? I ran a jumper just to see to the pos terminal and no dice nothing moved. You know anything about it pezi or any of yall other regs?
PEZi
should be internally grounded
synack7350
roger so the 12v should have popped it open. bummer looks like its not working guess i'll have to give em a call
synack7350
my throttle linkage
PEZi
^ same as mine
Return to “Datsun 720”
