There is not any mechanical key slot to start the car. When the battery in the key dies you put it in the slot and you can start it that way. Otherwise with a good battery it is not necessary to put the key in the slot to start the car.psyopper wrote:Try tightening the hinges on the door and frame to fix the popping.
I'm new to the M35 as well. I know where the fob slot is on the dash, but where is the mechanical key slot to start the car?
The popping is coming from inside the door. I do not think tightening it is the solution. Unless I have to open the door up.psyopper wrote:Try tightening the hinges on the door and frame to fix the popping.
