Pic's of my Phatka-t turbo kit :)
s14det
Thought i would share some pics of the turbo install. I always like to see pics of turbo ka's so I thought I would share mine. Just waiting on my ECU from enthalpy then I will be able to have some fun
Turbo kit hasPhatka-t GT32 turboPhatka-t Manifold, Downpipe and Wastegate dump tubePhatka-t Fuel system with 50lber'sBoostdesigns Intercooler kitTial wastegateZ32 maf
Engine already has s13 cams, Fidenza flywheel, ASP pulley, Koyo, Blitz exhaust. Other then that engine is stock internaly
http://www.imagestation.com/al...43625
http://www.cardomain.com/ride/2052320
Thanks for looking Marcus
Modified by s14det at 3:05 AM 7/15/2005
Modified by s14det at 5:04 AM 7/15/2005
Modified by s14det at 6:04 AM 7/15/2005
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
looks good what kinda numbers are you getting
MarkEmark
Car: fully-built '95 240sx KA-T
s14det wrote:Thought i would share some pics of the turbo install. I always like to see pics of turbo ka's so I thought I would share mine. Just waiting on my ECU from enthalpy then I will be able to have some fun
Turbo kit hasPhatka-t GT32 turboPhatka-t Manifold, Downpipe and Wastegate dump tubePhatka-t Fuel system if 50lber'sBoostdesigns Intercooler kitTeil wastegateZ32 maf
Nice, lotsa top-notch stuff in there! Not sure why the FPR is mounted like that though, it makes it a bit hard to read the gauge, no?
nismofly
Car: 89 Nissan 240SX Hatch
basically same stuff ill be doing when i swap in my dual cam engine, let us know the different number results
also why are you only running 50lb injectors? i would think 72lb units would be able to use the gt32 to its full potential
s14det
Thanks guys. That is about the only place I could find to mount the FPR. It is easy to read the gauge tho. This is still a stock engine so my limit for HP is 350. 50lber's will work for now. When I rebuild, then I will get bigger injectors. Plus when I ordered the kit, Phatka-t was not offering the 65lber's like they are now. For now i only plan to run about 300-320hp max. I hopefully will get to the dyno in a month or so.
Craving4Boost
Car: 91 240sx fastback
can you post up those pics on NICO im to lazy to create an account lol....how was the installation? im sure PK's turbo kits were easy to install with good quality..i would like to know how that enthalpy ECU goes too
sean8564
1993 Nissan Silvia
if you want bigger numbers Z32 maf pistions rings and rods with 550cc's and a SAFC II or emanage you should be fine BOV and external waste gate
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
how much did all that cost?
s14det
All the stuff from Phatka-t was about 3200 or so.
Craving4Boost
i wish i woulda spent that money in the first place..i tried to go cheap but ended up spending 3000$ still
s14det
I was thinking the same way. I was going to buy the Boostdesigns kit, them I was thinking, if i am going to buy all of this I am going to save a bit longer and get the best turbo kit for the KA. (I actually borrowed money from the bank, which will be paid off once I sell my Ford probe )Best in my book anyway, since they have proven it makes power. Wish I had the money for the AEM, but for now the enthalpy ECU should rock
S14tat
Car: 2007 FX35
1994 Acura NSX
1996 Honda Accord coupe
1995 S14 KA-T *sold*
wow that kit looks super high quality even on a customers car.
nissanfanatic
Car: 1992 Nissan 240sx SE
Pimp **** man. How is it on the street?
Def get some track times and numbers.
cyrus240sx
Car: 95 240sx with five lug swap, rims, suspension, I H E, remote start, too bad its auto
that setup looks awesome... i love the look of the manifold... all black with a nice huge shiny turbo under it.... makes it look like it means business
skatanic28
Car: 96 240sx
looks good
make sure ya post up the dyno when you get it running, im interested in the powerband with that turbo. the last chart i saw built like 10psi almost instantly.
s14det
I will Def. post the results up. Dyno and track times. My dad just got a new C6 vette, so we are going to go to the 1/4 track and have some fun
I hope to get some roadracing and cone racing (autoX) in this summer also
