PIC REQUEST!!!! T25 /T28 oil Return line on the KA24DET
The All Mighty KA-T
Car: 1995 Eclipse GS-T
i'm needing a pic of the oil return line on ka24det with a t25 or t28 turbo setup.......i'm just needing to see where you tapped into your oil pan to return the oil from the turbo..................thanks guys.
Florida240sx
You tap your oil pan wherever.....doesn't matter on turbo. Closest to the top of the pan as possible. I have mine right behind the a/c compressor.
sdtouge
Car: 1990 240sx coupe
how about behind the motor mount on the oil pan, right below a t2 setup.
im gonna trim off that little ridge to get it as high as possible, see anything bad about this being so far back?thanks
DRFT(kinda)
Car: 2005 Nissan Titan.
The only thing you need to keep in mind with the return line is that it need to be as stright down as possible with as little bends as possible. After that you can do whatever you want with it.
