pic request
SplitSecondConcepts240
Car: 93 240sx
i need a pic of a ka to point out a hose i need info on. im gonna have to replace it asap
benemorius
Car: s13, s13, eg, e36
single cam or dual?
Car: 93 240sx
dual
KDashy
Car: '97 Nissan 240SX
Car: 93 240sx
pic
benemorius
Brake booster vacuum hose. What all do you need to know?
Red coupe
Car: 92 Nissan 240sx Coupe
??? what about it?check my sig, FSM will have vacume diagrams to the engine bay, you should be able to figure out what hose it is from that.
Car: 93 240sx
it has a tear and when its open my car wants to turn off and when its closed it runs fine
Red coupe
k...do you want to ask a questionat any point ? or you got what you need? That hose supplies vacume to your brake booster, do you still have power brakes?
Car: 93 240sx
yea i figured it had to do with the brakes ,why does it affect the motor?
benemorius
It creates what is called a vacuum leak. It lets air into the intake which didn't pass through the MAF and therefore the ECU doesn't know to add fuel for it. It leans out the engine, causing poor running or stalling depending on the severity of the leak. Replace the hose as soon as you can. If it should happen to tear wide open while you're tring to brake.... bad news!
Car: 93 240sx
thanks i really appreciate it
