PIC REQUEST:Sleepy Eye switch.
Ghettokracker71
Where/How did you mount your sleepy eye switch? I want to put one in,but I want to keep everything clean...NO switches on dangling wires or something like that.
POS_S13
Car: thizzlamics
do the free quick sleepy eye mod. all it includes is cuttin a wire and no need for extra switches. someone did a writeup on here about it. it works great, seriously shouldn't take longer than like 2 mins.
elvis240sx
i recently put in a switch for my amp subs in the remote turn on wire so i can switch them off right in the drivers seat when changing cds or songs. anyway, i also didnt want any switches showing so i put it inside of the console. right under your right arm where you lift up the door, it has the shallow part and then the deep part. there are two holes already made in the shallow part on the wall that faces the shifter. it fits those small metal toggle switches very nicely, just take the collar off the switch, pop it through, and screw the collar back on. viola! you never know its there!
Ghettokracker71
POS_S13 wrote:do the free quick sleepy eye mod. all it includes is cuttin a wire and no need for extra switches. someone did a writeup on here about it. it works great, seriously shouldn't take longer than like 2 mins.
Hmm...I don't want ghetto stuff (IGNORE THE SN ,lol) I'd like it to be nice....what else do you do besides cutting a wire(I'm sure its more involved)
[Zero-S]
Car: Tell me whats wrong with this picture. 3 240's, only one runs.
No, you just cut a wire. Seriously.
Mr1der
unplug the motors and screw the lights up.
they just won't come down.
Treyz
Car: 240SX S13 Fastback
OK Cheap sleepy eye mod -
- Get a toggle switch (or im my case, a push button)- Get some extra wire- Drop ur lower driver's side dash- Pull/pop out your cruise light switch (pop up button)- Behind the harness plug there will be one pale green wire- Snip the wire with enough room on both sides (meaning DO NOT cut the wire at the harness!)- Now, with extra wire, connect both ends to the switch/button- Drill a small hole into your lower dash that you took off earlier.- Install switch/button to hole you made- Put car back together- Now (with the switch off if you chose a toggle switch) push your cruise light button so that the lights are flipped up. When you push the button again to the off postiton, the ligths should still be up. Now adjust the lights with the switch/button you installed till desired position.- Enjoy!
*NOTE: It is common for the lights not to fall evenly. If so, pop open your hood and pop the cap off the motor revealing a knob. Now twist the knob till they're even. I know it's annoying but that what you get for the cheap way unless you want to spend $60-$100 for the axtual pivot kit. I'd advise not to pull up on ur headlight to even them out. It will make the light a little loose when flipped up fully (trust me I know).
Now originally I used a toggle switch but found it annoying to switch it on and off to adjust the height of the lazy eyes. So the solution was just buying a push button instead and it works 10 time better in my eyes. Not only that, it hides better than a toggle switch.
See, you don't see a switch at all but, it's there under the lower dash panel.
Ghettokracker71
Thanks! I have a spot drilled right under my hood release where I had an remote amp control,I'll try to firgure out how to put it there. Any other ideas would be appreciated.
driftin8ez
Car: 92 Coupe, Turbo Miata
regarding lazy eye. I did it for free. Just pop out the button that controls lights to go up or down without turning them on. Cut the two bottom most wires. I believe one is brown??? Your done. Play with it a little. When the button is active you should be able to turn your lights on and when you turn them off they will stay popped up. now tap the switch a few times stopping the lights were you want them. simple.
I posted this a while back. An abridged version of a how-to.
rousie13
Car: 2006 Nissan 350z Track Edition, 1997 Ford F250 4X4
I put my 2 toggles in that little pice on my dash that pops out. It's on the right side of the wheel. I have one for my lights and another for my one fan. Looks good where it's located. I can get pics if you guys want.
Ichi-Go
You can also turn your headlights on then have you hand on the motor fuse in the driver side kick panel. As the lights are going down pull the fuse. It takes a couple tries to get it were you want it but it works. When you turn on your brights the headlights popup all the way.
whiterps13
Car: white LE hatch
you dont need any extra wires or buttons or anything!!! i was really skeptical too but all you have to do is cut the brown wire. TRUST ME, IT WORKS AND ITS FREE! what more could you ask for?
Ghettokracker71
You said just cut the brown wire but the other guy says to cut the brown wire and another one? What's the deal?
whiterps13
Car: white LE hatch
look in the 240 technical forum, there is a whole thread about it.
bokinsmowls
Car: Should be obvious
cutting the brown is definitely the way to go, took less than a minute, works great. only downfall I see is not being able to have the lights on while in "sleepy" mode. do any other kits let you keep the lights on?
240Knightrider
Here is mine
rousie13
bokinsmowls wrote:cutting the brown is definitely the way to go, took less than a minute, works great. only downfall I see is not being able to have the lights on while in "sleepy" mode. do any other kits let you keep the lights on?
The way I did it you can have the lights on while in sleepy mode(only way you can do sleepy eyes). I don't like the lights up at all when they're off, so I wired it so sleepy is only when the lights are on.
240Knightrider
im gonna buy the real kit soon to replace my little switch though. Im not into the cutting of wires and stuff to much.
bokinsmowls
i figure if i dont like, then hook the wire back up. just leave enough wire to play with
rousie13: how you wire with lights on?
UTWarrenG
sorry to highjack the forum, but......
Treyz, how did you get the plastic cover that goes around the headlight buttons, and is right below the gauge cluster off?
I'm interested in painting mine like you did, just a different color.
Ghettokracker71
UTWarrenG wrote:sorry to highjack the forum, but......
Instead of being sorry,just don't. Why can't you PM him or email him?
Sorry to be an *******,but this thread finally got some replies...
Treyz
Ghettokracker71 - The reason why i had cut the pale green wire is cuz of the fact that yes i have sleepy eyes during the day, but when i turn on my headlights, they flip up all the way like they normally do. Then when i turn them off, i just simply reset my sleepy eyes with the push button i installed...what does it cost like $3 for the switch.. it's not like ur paying $60.
Also, no need to get defensive about UTWarrenG's post. he just asked a quick q.
UTWarrenG - Basically take the lower dash off like i stated before (10mm)...take out the two screws above (philips)...then under the steering column there will be two 14mm bolts to take out the drop it...then it'll come out easily. (BTW u need to take out the plastic housing from the steering column before u can get to the 14mm)
