http://www.canadianautoreview.com/fx35-wheel-700.jpg
...Not without spacers and a smaller tire sidewall...240sx_Guy wrote:that is correct rex. so that would be a no, it will NOT fit?
...Which is what you would need. Because those high offset wheels are gonna be soooo sunken into your wheel well that the tire will be rubbing the fender lining. The spacer will move the wheel/tire away from the fender lining and prevent the rubbing. A 20mm spacer should have you pretty flush.240sx_Guy wrote:wouldn't spacers take the wheels out even more?
They're 18s in the front and 20s in the rear.Dazzla wrote:Those are def not 18's...the wheels on that green kouki look like 19's or 20's.
Look at the rears, I have 18's on my s14 and there nothing like that...
