X owner and Espelir spring user. There's enough difference between the AWD and sport models that I didn't want to risk it. Different front weights, different components, and a whole slew of electrical components that engage and disengage the AWD system. Tein's have been done by one other member that I could find in my research but nobody (that had posted) that had had them longer than a few months.Noel J wrote:M35x here. From what I've read on some of these threads, the Espelir springs (did I spell that right?) is the way to go with AWD lowered suspension.
All 3 of my Infiniti's have been X's . . .honestly i'm starting to dislike them . . I always end up getting an X for the AWD capabilities . .but with the problems that follow when it comes to lowering and the whole issue about staggered wheels on AWD . . .i'm starting to think it's not worth it . . .fiveliterbeater wrote:you know, now that you mentioned it, i don't think we have a lot of X owners in here. we should do a M35X roll call.
In your sig it says the AWD Espelir dropped the front 1" and the rear 1 1/2"??? . . .the way the X sits now the rear height isn't actually that bad . .the front however looks horrible, completely 4x4 lol. . .I don't think I would want the front dropped 1" while the rear gets 1 1/2" . . .to me it seems like it should be the other way around . . .stumbleweed wrote:
Good luck and make sure to post some pics when you finish!
Unfortunately, that's as far down as the front would go on springs. Initially the rear drop was even lower, i brought it back up to offset the visual appearance. After settling (need to update my sig) they're now both about even at 1.5". Here's a cross-post to the write-up I did with pics before it settled. At the end of the day, anything was better than the SUV appearance I had before doing the drop...Big Raj wrote:
