Pic Request: 18s on an S13. And how'd you make it work?
roplusbee
Car: 2007 350Z NISMO
I am sure someone out there has 18x8+ wheels on there S13. I am looking to do this, but I am certain that some work is necessay. I don't plan on lowering (maybe, but Naples roads are horrible), so I hope to be ok for a bit. Lemme know what you guys did to make it work lowered or not. I have 18x8.5 F and 18x9.5 R on the way. I still need to find tires and have thought about 235/40/18 F and 245/40/18 or 255/40/18 R. Lemme know what you guy got and also what you think
Thanks.
Rob
Repo Man
Car: 2020 Frontier Pro4X
2003 Honda Accord
What offset are the wheels that you're getting?
MustangManV6
Car: 1995 Subaru Impreza
Wow, not going to lower an S13 with 18s...
Nissan rydin high lol
ArticDragon192
Car: 91 Z32 2+2
To make them fit:Unbolt old wheels.Bolt on new wheels.
^ Exactly.
I'm seeing them work with narrower widths and strtched tires... The rear is easy, the front, not so much. But it can be done.
Felipe
Car: abcdefghijklm nopqrstuvwxyz `1234567890-= ~!@#$%^&*()_+
18s ouch!
PoPUp'S
Car: 93 240Coupe
Trow SOme D's On That 8ICHT!!!....................................................................NOT!!!
babowc
Car: 240sx
those tires are going to be hard to stuff in the front.18x9.5 itself is going to be hard to stuff in the front alone.
Car: 91 NISSAN 240SX
18s with no drop would look like dookie
roplusbee
The offset is +30 on both. The fronts are 18x8.5 and the rer is 18x9.5. I want to lower, but I will hold off till I get to an area w/ better roads. Sorry for not specifying the offset before (forgot about that).
ArticDragon192
Car: 91 Z32 2+2
They'll fit but the offset is pretty weak. Especiallt at stock ride height. You have little to worry about.
masterteque
Car: 1993 s13 convertible 1993 s13 coupe
Here are mine with 18x8.5f and 18x9.5r. Both have a 35mm offset with a 10mm spacer on front. 225/40 on front and 245/40 on rear...I don't think I would do this without lowering though.....
Nick240sx
Car: 2009 Ford Fusion SE Sport
masterteque wrote:Here are mine with 18x8.5f and 18x9.5r. Both have a 35mm offset with a 10mm spacer on front. 225/40 on front and 245/40 on rear...I don't think I would do this without lowering though.....
hey ive seen your car around here. im WC too. is that the parking garage by the Y or the one off of high street and market?
roplusbee
Cool. I feel better then. You didn't have to roll your fenders did you? And how much did you lower? I was thinking 225/40 F and 235/40 R. Now I will go w/ th 245/40 R. Thanks
Modified by roplusbee at 3:18 PM 4/11/2007
le_ryan
Car: Mazda3
91 Nissan 240SX SR
masterteque
Nick240sx - These were taken on top of the High and Market Street garage....
I didn't roll the fenders and I believe it's lowered about 2 inches...I have coilovers on it so I am not really sure....
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
18x8, all around. (im a whore)
Kckouki
Car: '97 Nissan 240SX
That looks damn good.18's are to big imo, even on an s14.
Felipe
what tires you running
nonvtecaccord
So effectively you have a 18x8.5 with a 25mm offset up front.
masterteque
yes...25mm...8mm will just clear coilovers with some negative camber....
thenillaz
Car: 92 240sx Hatch
BTW masterteque, with 18s and 40 series tires, do you experience any rubbing of the inner wall when you turn your wheels to full lock?
roplusbee
masterteque wrote:yes...25mm...8mm will just clear coilovers with some negative camber....
That is just the information I needed. As far as negative camber, how much did you use? I will probably stay pretty close to stock height (nervous about Naples streets) until I get to a better area. I still have to pick up coilovers or springs/dampeners to complete my suspension. Thanks again.
Rob
WWJD
if your worried about street condish. I would stay away from 18's, 17's will offer better cusion. I have a set of 18's on one of my s13's stock suspention (NOT BY CHOISE)and bumps worry me
masterteque
thenillaz wrote:BTW masterteque, with 18s and 40 series tires, do you experience any rubbing of the inner wall when you turn your wheels to full lock?
No rubbing at all....I don't think 18's are too harsh for the streets and I am on s**tty PA roads. That just my opinion......
yokota180sx
Car: 1997 Stagea RS4, r34 front
18x9 -5 front18x10 +10 rear
masterteque
sick wheels and offset..
yokota180sx
il iked these better hoenstly
18x9 -518x10 +20
roplusbee
Did you roll your fenders Yokoda? I still haven't gotten tires yet. Hopefully my tempo will slow down so that I can get my ride finished up. Again, good to see you back.
yokota180sx
roplusbee wrote:Did you roll your fenders Yokoda? I still haven't gotten tires yet. Hopefully my tempo will slow down so that I can get my ride finished up. Again, good to see you back.
front and rears on both cars
