Pic of my engine.
dash
Car: s13 ca18
post some current specs for 600hp. Too nice to leave out details
12.13sec 1/4 on stock bottom end and cams ?what done to motor.... what method of tuning.... turbo... full wt s13 ??what gearbox, diff, gear ratio & tires ?
Chinamandrift
Car: ca18det powered ae86
can you show me how you made all that stuff ??? did you just grind the stock pulley down???....... how did u make the fuel rail? ........i bought one on ebay from australia .....then i found out 8 port and 4 port fuel rails are different..........they sent me the 8 port ......and i have a 4 port .......bummer...
but anywayz did i tell ya i love your crank pulley ........if u dont wanna show me how to make one ........u wanna make one for me ???
Giallo spyder met
Car: Nissan 200sx -92 Euromodel
Chinamandrift wrote:can you show me how you made all that stuff ??? did you just grind the stock pulley down???....... how did u make the fuel rail? ........i bought one on ebay from australia .....then i found out 8 port and 4 port fuel rails are different..........they sent me the 8 port ......and i have a 4 port .......bummer...
I tried to grind the stock pulley but it trashed.This i have now is machined out of one piece alloy.
Also the fuelrail is made from one piece alloy.
But we have a company in Sweden that sells fuelrail to ca18det 4 port head.Its called Nuke-performance (http://www.nukeperformance.com/)
Ofcourse i can make more alloy pulley without powerstering and AC but it will cost almost 300usd.
More pics soon.
Chinamandrift
300 usd for the pulley ......deal .....paypal?? jk ....wait no really do you take paypal ??? hahaha
did i mention i love your pulley
i looked on the site .....its in gadfsbasbhjj language....i emailed them tho .....hopefully they speak english too
yourmomsrps13
Car: Drifting ruined my life since 03' 240sx CA18DET
Chinamandrift wrote:300 usd for the pulley ......deal .....paypal?? jk ....wait no really do you take paypal ??? hahaha
i wouldnt change your OEM pulley unless you plan on balancing the rotating assembly, like im sure he did when he built his motor.
themadscientist
fuel rail
cam sprockets
FPR
Y-block
Vacuum station
Chinamandrift
hmmm u make a good point ........does the oem have soemthing that counters belt tension ? and vibrations ?? ......cuz the last time i looked at it ......its just a metal pulley ...im far away right now ...so i cant take a look
jt15833
Car: 95' 240SX
I'm pretty sure they call it a harmonic balancer / crank pulley damper, I think it has some type of rubber insulation in it to dampen the vibrations and such, but you lose that by switching to a pulley like that.
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
Giallo spyder met
yourmomsrps13 wrote:i wouldnt change your OEM pulley unless you plan on balancing the rotating assembly, like im sure he did when he built his motor.
Every moving parts in my bottom is balanced.
Giallo spyder met
http://www.s13.se/viewtopic.php?f=17&t=379
I think his a member here too.
iliketocrash
i thought the crank had to be fully counter-weighted to be able to do away with a harmonic dampener? and our cranks aren't
Giallo spyder met
iliketocrash wrote:i thought the crank had to be fully counter-weighted to be able to do away with a harmonic dampener? and our cranks aren't
I dont know what counter-weighted is?But my crank flywheel clutch and pulley are ballanced just so i can change anything of them and just have to balance the new part.
Giallo spyder met
themadscientist
The CA crank is half counterweighted, it should need an external balancer as a result I would think.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Man I really want a fully counterweighted crank.
Giallo spyder met
r34 gtr wrote:Man I really want a fully counterweighted crank.
Ooh now i know what you mean.Tomei is the only i know you buy for about 4200usd.
I want a fully counterweighted knife-edge forgde crank.Were to buy?
themadscientist
There is no fully counterweighted crank for the CA18, anywhere. The Tomei CA20 crank is just a modified Nissan OE CA20 crank.
r34 gtr
You could definitely have one made for less than the price of a Tomei unit. It would be really expensive though. If you have access to a bada$s 5-axis machine you could always make one yourself.
