moso »
https://forums.nicoclub.com/moso-u137641.html
Tue Nov 10, 2009 10:53 am
the speed sensor plugs in to the lower harness near the starter, it has two wires and it sits low on the transmission near the rear on the passenger side, it hooks up the same on the auto and the manual so there is no wiring to change there. you may have a bad sensor. as far as the reverse lights go i wired the reverse switch on the transmission to the connector end i cut off the auto trans gear selector switch. if your familiar with a multimeter you can just put the auto gear switch in reverse and see which wires connect, those will be your reverse light wires. i believe thay are Green/Blue to one side of the switch and Green/White to the other side.
