Im trying to do a simple parasitic draw test like Ive done on another vehicle, where you simply disconnect the negative and connect the multimeter to the negative battery terminal, and the now disconnected ground cable, and the meter shows the amperage/milliamps being drawn out, my meter is showing zero, and I know there should be a small amount but Im likely experiencing a lot, so Im confused how Im testing incorrectly. I put the red probe over to the 10A connector on the bottom of the DMM, anybody see anything incorrect?
