MarkEmark »
https://forums.nicoclub.com/markemark-u744.html
Mon Mar 08, 2004 4:31 pm
I'm thinking of upgrading to a T3/T04B (.48 a/r turbine, .60 a/r compressor, 54 trim wheel) but do NOT have a lot of space between my turbo right now and my shock tower. (I have a T3 super 60, .48 a/r turbine, .60 compressor right now). Right now my compressor outlet points down toward the ground, but I could always point it up (like cdigity's setup) since the turbo sits low enough and I have to re-do all my piping to have it intercooled anyway, but even with the outlet pointing up, the overall diameter of the compressor housing (or the 'scroll,' if you will) may have clearance issues if I get the larget T04B compressor.
So my question: Does anyone know where I can find the exact physical dimensions of a T04B compressor with the aforementioned specifications, such as the diameter of the overall compressor at its widest point?
If anyone is running a similar T04B compressor, (*cough* c-kwik *cough*) would they be able to make a fairly accurate measurement of the overall diameter of the scroll, and also a measurement of the part of the outlet furthest away from a line drawn tangentially to the left side of the compressor and perpendicular to the way the turbo sits when looking at it face on and the outlet pointing down?
It's kinda hard to visualize, but any info would be appreciated.
