Code: Select all
<?xml version="1.0"?>
* Magento
* NOTICE OF LICENSE
* This source file is subject to the Academic Free License (AFL 3.0)
* that is bundled with this package in the file LICENSE_AFL.txt.
* It is also available through the world-wide-web at this URL:
* http://opensource.org/licenses/afl-3.0.php
* If you did not receive a copy of the license and are unable to
* obtain it through the world-wide-web, please send an email
* to [email protected] so we can send you a copy immediately.
* DISCLAIMER
* Do not edit or add to this file if you wish to upgrade Magento to newer
* versions in the future. If you wish to customize Magento for your
* needs please refer to http://www.magentocommerce.com for more information.
* @category Mage
* @package Mage_Core
* @copyright Copyright (c) 2012 Magento Inc. (http://www.magentocommerce.com)
* @license http://opensource.org/licenses/afl-3.0.php Academic Free License (AFL 3.0)
<config>
<global>
<install>
<date/>
</install>
<resources>
<default_setup>
<connection>
<host>localhost</host>
<username/>
<password/>
<dbname>magento</dbname>
<model>mysql4</model>
<initStatements>SET NAMES utf8</initStatements>
<type>pdo_mysql</type>
<active>0</active>
</connection>
</default_setup>
<default_write>
<connection>
<use>default_setup</use>
</connection>
</default_write>
<default_read>
<connection>
</connection>
</default_read>
<core_setup>
<setup>
<module>Mage_Core</module>
</setup>
<connection>
</connection>
</core_setup>
<core_write>
<connection>
<use>default_write</use>
</connection>
</core_write>
<core_read>
<connection>
<use>default_read</use>
</connection>
</core_read>
</resources>
<resource>
<connection>
<types>
<pdo_mysql>
<adapter>Varien_Db_Adapter_Pdo_Mysql</adapter>
<class>Mage_Core_Model_Resource_Type_Db_Pdo_Mysql</class>
<compatibleMode>1</compatibleMode>
</pdo_mysql>
</types>
</connection>
</resource>
<models>
<varien>
<class>Varien</class>
</varien>
<core>
<class>Mage_Core_Model</class>
<resourceModel>core_resource</resourceModel>
</core>
<core_resource>
<class>Mage_Core_Model_Resource</class>
<deprecatedNode>core_mysql4</deprecatedNode>
<entities>
<config_data>
<table>core_config_data</table>
</config_data>
<website>
<table>core_website</table>
</website>
<store>
<table>core_store</table>
</store>
<resource>
<table>core_resource</table>
</resource>
<cache>
<table>core_cache</table>
</cache>
<cache_tag>
<table>core_cache_tag</table>
</cache_tag>
<cache_option>
<table>core_cache_option</table>
</cache_option>
</entities>
</core_resource>
</models>
</global>
<default>
<system>
<filesystem>
<base>{{root_dir}}</base>
<app>{{root_dir}}/app</app>
<code>{{app_dir}}/code</code>
<design>{{app_dir}}/design</design>
<locale>{{app_dir}}/locale</locale>
<etc>{{app_dir}}/etc</etc>
<media>{{root_dir}}/media</media>
<upload>{{root_dir}}/media/upload</upload>
<skin>{{root_dir}}/skin</skin>
<var>{{var_dir}}</var>
<cache>{{var_dir}}/cache</cache>
<session>{{var_dir}}/session</session>
<tmp>{{var_dir}}/tmp</tmp>
<pear>{{var_dir}}/pear</pear>
<export>{{var_dir}}/export</export>
</filesystem>
</system>
<general>
<locale>
<code>en_US</code>
<timezone>America/Los_Angeles</timezone>
</locale>
</general>
</default>
<varien>
</varien>
</config>
