you can go wider tires than that, i'm sporting 255 wide rubber with +40 offsetlvnitup00 wrote:215/35/18.
sounds to me like a good fit right?
I'd run that through a calculator to see what it would do to your speedometer. You need to check the offsets for those rims if they came off a RWD 240sx as some of those guys love +20mm and less which may be a challenge on an altima.lvnitup00 wrote:215/35/18.
NOOOO!!! That's the most awfully setup I've seen so far...lvnitup00 wrote:215/35/18.
I like this one:http://www.miata.net/garage/tirecalc.htmllvnitup00 wrote:how do i do the calc?
Single parent with kids at the time. Moved near other family members and for a higher paying job.lvnitup00 wrote:lawrenceville is alright, same old i guess (nothing special happenin) too quiet for me.
why'd you move?
Those Enkei's aren't offered in low offset.audtatious wrote:You need to check the offsets for those rims if they came off a RWD 240sx as some of those guys love +20mm and less which may be a challenge on an altima.
whats ur offset?alphapig wrote:But please learn the offset before buying!
Specs are 18x7.5 +35 offset. 225/45/18 tires.lvnitup00 wrote:whats ur offset?
