Photoshoot, turbo upgrade and s14.5 conversion pics
driftking561
Car: ka-t sil80
Operation greddy Mon-Star: s14.5 ka-t
Turbo: GReddy TD06 20G turbo ( 12 psi actuator spring) GReddy Log manifold Greddy Turbo elbow and downpipe Greddy Type S BOV SS oil feed and return lines
FUEL: Walboro 255 fuel pump RC Engineering 650cc Injectors Turbo240 AMS Top feed Fuel Rail Z32 Fuel Filter
Air: Greddy Front Mount Intercooler Z32 MAf Greddy Air Intake Filter
Cooling: CX Racing Aluminum Radiator CX Racing Dual Electric fans CX Racing Aluminum Fan Shroud Custom Aluminum Pipe for SR Radiator to be used with KA 185 Degree Thermal Switch
Suspension: Silk Road RMA8 Adjustable Coilovers Peak Performance RUCAs, Rear Toe links Peak Performance 5 lug Hubs Z32 front Calipers and Rotors, SS lines Aluminum Driveshaft, one piece 18x9.5 +12Work Emotions, Kuhmo Ecsta tires Cusco Front Strut Tower VLSD OEM
Block: JE Forged Pistons 89.5mm dish 9.0:1 compression Cometic Headgasket ARP Head studs
Ect…: B&M Short Shifter Nismo Shift Nob Custom Magnaflow Exhaust Jim Wolf Tuned ECU
Pictures
SR24DET
Car: RMS13
It looks really nice. I love your rims. I am really confused on your turbo setup before this top mount setup. Your intake pipe looks like its going directly to your turbo with no cooling process. No FMIC, No SMIC? But it looks sick now.
WDRacing
Got any pics of the turbo drain bung? Were you able to use the same location with the new setup? I only ask because I'll be using a similar manifold and turbo location as your intial setup. But I won't be installing the manifold and turbo for awhile. However, I have the motor going in tomarrow, so I'd like to weld up the return bung before then...for obviousl reasons.
WD
driftking561
Car: ka-t sil80
SR24DET wrote:It looks really nice. I love your rims. I am really confused on your turbo setup before this top mount setup. Your intake pipe looks like its going directly to your turbo with no cooling process. No FMIC, No SMIC? But it looks sick now.
Thats because i wasnt running an intercooler. Intercoolers arent absolutely nessacery for mild turbo applications. im making alot more power now hints the GReddy frontmount upgrade.
driftking561
Car: ka-t sil80
WDRacing wrote:Got any pics of the turbo drain bung? Were you able to use the same location with the new setup? I only ask because I'll be using a similar manifold and turbo location as your intial setup. But I won't be installing the manifold and turbo for awhile. However, I have the motor going in tomarrow, so I'd like to weld up the return bung before then...for obviousl reasons.
WD
Not specificly i was able to use the same location it wasnt a problem at all. I used an 90 degreee adjustable AN fitting that i could turn up and down on the return bung. Only thing i had to do was get a long SS braided line i even used the same end pieces
Wheelieguy
Car: S13
Car looks good, and that Red Coupe is nice too!
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
what a cute little intercooler, i just want to pinch it. too bad i sold my greddy type-M intercooler. where are you in socal? More ka-ters in socal now, we should have a meet even though i'm fully built N/A at the moment. GL
madd ocx
Car: 1995 nissan 240sx
here is a piece of advice. since you are rocking the 20g many people including myself experience boost creep by:1 taking off the restrictor plate on the intake pipe, or2. putting on a bigger than stock downpipe.usually doing one or the other isn't a problem but when you do both is when you really get the creep. but nismo240 on ka-t.org put me on to a cheap fix. send your turbo out to a place in waco texas called majestic turbo (www.majesticturbo.com) and get the wastegate ported and weld on a bigger flapper and your turbo will be creep free. i did it myself and no longer have any problems. so for only 125 bucks you can fix the boost creep woes of the 20g.if your not having the problem then cool but if you do come across it then this is the solution guaranteed. if you have any questions just ask, i don't mind helping out.
driftking561
Car: ka-t sil80
madd ocx wrote:here is a piece of advice. since you are rocking the 20g many people including myself experience boost creep by:1 taking off the restrictor plate on the intake pipe, or2. putting on a bigger than stock downpipe.usually doing one or the other isn't a problem but when you do both is when you really get the creep. but nismo240 on ka-t.org put me on to a cheap fix. send your turbo out to a place in waco texas called majestic turbo (www.majesticturbo.com) and get the wastegate ported and weld on a bigger flapper and your turbo will be creep free. i did it myself and no longer have any problems. so for only 125 bucks you can fix the boost creep woes of the 20g.if your not having the problem then cool but if you do come across it then this is the solution guaranteed. if you have any questions just ask, i don't mind helping out.
Appreciate the heads up. Luckily for me the guy i bought the turbo from already welded on a bigger flap and got that problem corrected. As of now im experiencing no problems besides an idle problem at WOT. but i had that problem even when i had the t28 setup. Cleaned the IACV and still trouble-shooting. Got word that it might be a insufficent ground.
Do u know any bigger downpipes that have the GReddy flange.? would rather upgrade to something that somwthing that woulod boltup without modifaction
madd ocx
not that i know of.. my down pipe is custom made.. greddy made the kit to fit the stock downpipe. most people i know have a custom downpipe made for it..
joenismos15
Car: 1995 Nissan 240sx SE
I used a Megan Racing SR20 Downpipe from my Greddy kit Down pipe, Ill take a Pic to show you what i mean, but ill try to explain anyway, From the Turbo i used the Greddy pipe included with the Kit, Then from the end of that pipe i used the Megan Sr20 down pipe, then i have my catco Cat, then my hks turbo back exhaust.
driftking561
Car: ka-t sil80
joenismos15 wrote:I used a Megan Racing SR20 Downpipe from my Greddy kit Down pipe, Ill take a Pic to show you what i mean, but ill try to explain anyway, From the Turbo i used the Greddy pipe included with the Kit, Then from the end of that pipe i used the Megan Sr20 down pipe, then i have my catco Cat, then my hks turbo back exhaust.
ooh ok i understand. i was thinking of getting a bigger turbo elbow, like from the turbo exhaust housing.
