All pics are now narrated and most questions should've gotten answered. Since I'm off from work today, I probably will go out on the highway where it's open and try and tune this boost controller past 20 psi. Then hopefully, get the car to the track maybe tonight or tomorrow if it doesn't rain. Oh yeah, the turboboost_boy wrote:Attached is a dyno run from last year (2004)with my old HKS camshafts and this year(2005) with an nternally stock CA18DET.
This pull was one of the ones done last year before I refreshened (with block still in car) my 3 year old stock CA18DET with HKS 264 duration w/8.5mm lift camshafts and turbocharger is a T3/T04E stage III with .60 A/R and a .48 rear housing. For some reason this engine puffed a lot of white smoke even on the dyno, but never once mixed the oil and water.
This pull was done with conservative timing after battling with a faulty fuel pressure regulator. All of us were at peace when we saw the A/F ratio. This was also done on 12-13psi of boost with T3/T04E stage III hybrid with a special wheel that I won't reveal just yet, but soon. With the new wheel, the car stays on boost with a quick gear change from 2 to 3rd from 3rd to 4th and pulls happily in 5th. With the wicked gear ratio, 6500rpm, the car was already doing better than 150mph on the rollers, but the lean condition from the bad FPR prohibited me from going further.
This pull was done on 12-13psi of boost as well with engine temperatures getting a bit erratic (leaking heater hose).
This pull was done at 20psi solid. Engine is still a bit warm, but I didn't care.
And this is a picture of where the car stands today. I will take it to the track, run it, and tear the engine down and install the goodies to included ported head, excellent reground cams, dual racing valve springs, CP pistons, ARP head studs, and NISMO 1.2mm headgasket.
Dee
