I'm glad you put the ZTE up there, it's a solid phone for not a lot money and it saves me the trouble of doing it.
However, my OnePlus instead recommendation stems from two specific things Ray mentions...
frapjap wrote: ↑Thu Jul 20, 2017 4:24 pm
- Long battery life
- Multi task. I like to run Waze and Pandora/streaming music at the same time.
All the other stuff is pretty even across the board; decent browser, internet speed, OS, 3.5mm jack, but the two I actually quoted set the OnePlus Five a bit ahead. Both phones have solid batteries (the Five has a 3300mAh and the Axon has a 3250mAh), but it's the processor that's the difference here. The Snapdragon 835 on the Five is more efficient than the 820 in the Axon. That same processor, and the extra 2-4 GB of RAM also addresses the other request - good multitasking.
Good Bluetooth is also mentioned, the Five uses Bluetooth 5 while the Axon uses 4.2. Bluetooth 5 is faster (2 Mbps vs 1 Mbps), longer range (200 m LOS vs 50 m) all while using less power. Bluetooth 5 also supports IoT devices while 4.2 does not. If you're an interactive house owner the choice is clear here, though they're an entirely different strata of phone user altogether.
The price on the Axon (and the Five to a lesser extent) is hard to beat, but I think it comes up a little short here because of what has been specifically requested.
Of any dings on the spec sheet for the Five the two that, I would think, would be most off putting to the average user it would be the USB-C charging (though I'm a big fan and it's the way it's all going anyway) and having to replace a bunch of cables and/or chargers. Though, of someone is switching ecosystems that's something that was going to be happening anyway. Then there's the lack of any dust or water resistance. I'm easy on my phones, haven't run a screen protector in years (I only use a slim profile case to add some grip) and the farthest drop my phone has had is when it gets knocked off the couch. But even
I think that it's a pretty egregious thing to skip out on providing any resistance at all.
