HAHAHAHA... Thanks Ethan. Sorry I didnt email you pix yesterday. They just didnt look good. And now it has windows and trim. So much better.Ebanks wrote:Sorry I'm late, I was taming this wild honeymoon stallion for you.
Looks almost as awesome as when you skiied into that picnic table in tahoe.
Yeah right Ivan, you have the like the worst reflexes ever!IvanAtSPRacing wrote:
Everybody knows I am training to be a cage fighter.
IvanAtSPRacing wrote:WD, I was actually thinking about you when I posted the pix. You gave me so much Sh1t for the multi color theme it was pimping before
Only cuz you love me, and I'm just givin you sh1t. Wouldn't be me otherwise
As far as the tires in the back. Those would be the all new Mickey Thompson ET Drag Radial in a 275-50-15 (26-10-15 for the americans here )
Do me a favor and snap a close up of the tread pattern
Thanks.S14tat wrote:wow i didn't expect to see the S15 front end on it. either way, it looks pimptastic. i definitly think the aerodynamics should help at the end of the track. i'm just curious to why you stuck with the 4 lug bolt pattern? was there no need for a 5 lug swap?
Thank you very much.AZhitman wrote:^ Good call. Besides, you're going in a straight line!
I'm confident in the NISMO studs as well, they look VERY beefy (I just installed a full set of the 60mm ones).
Ivan, the car is absolutely phenomenal looking. Well done, my friend, well done.
Any chance of getting her out here for the Nationals?
I have two garrett cores each rated at 450 HP. I have the water end tanks but will be making my own air flow end tanks. The beauty of liquid ICs is that they are so small and compact, pressure drop is less, and cooling ability is more. I cant wait to get building.WDRacing wrote:Very nice, whose cooler are you using? Or are you making a custom job? I was gonna make my own out a sidemount R32 IC. We'll see...
No FMIC will give you a nice sleeper look, so long as your BOV is tightened enough to not blow off unless your putting out 3-4 psi.
get some better tires.Tictakman wrote:ivan, what diff are u running or going to be running. im at 8 lbs of boost with an open diff and i get nothing but wheel spin...
car looks good by the way. im likin the color. Zak
Every chance I get. I have some races lined up when the car is done. It will be out there roaming on the Chicagoland streets.S14tat wrote:wow that is what i truely call a sleeper, no FMIC, no BOV. but how often is this car goin to hit the streets?
haha definitly a great way to make a quick buck cause you have really no true hint of the power that lurks benief ( spelling? ) the hood.IvanAtSPRacing wrote:Every chance I get. I have some races lined up when the car is done. It will be out there roaming on the Chicagoland streets.
