Il try to keep this as short and informative as possable.
S14
Was crashed into a curb (rear left wheel hit curb side on), made a decent sized gash in the wheel and bent arms and poss subframe.
took it off the road...
replaced drive shaft
Replaced subframe
all rear arms
fitted fortune auto toe arms
Solid subframe bushes
welded diff
solid diff bushes
now running 18x12 with 10mm slip on and extended studs
Took the car for a little test drive, was getting mad wobble just as i approach 30mph and onwards
jacked the car up at the rear, put it in gear to seeif the wheel was buckled, span perfectly true and straight but when on the ground it wobbled, also swapped wheels around, the wobble remained on the same side (LH).
I deduced this was the bearing, so i got a new one pressed in, refitted and put all back together earlier tonight.
STILL have what looks like a wobble, the bearing noise has gone exposing another noise which sounds like the coilover is nocking. sounds almost like loose locking collars but it isnt.
After driving forward and backwards with a friend watching the wheel we thought it could be the toe being way out (still hasnt been aligned), so i adjusted the toe and set by eye (did look kinda off before hand). This made the wobble somewhat better and the car felt more stable, i imagine the toe on both sides was that far out the LH wheel was being forced to skip back into line every few feet (if that makes sense).
So this is where im at now.
Im going to swap the coilovers round and see if the nocking chages sides to establish if the coilover is damaged.
Is it possible that i have actually bent the hub flange that the wheel mounts too with the impact? its pretty thick metal but are there any other cases of this happening?
tommorow im gunna jack it up take the wheel, caliper, disc etc off and try to rig up some sort of micrometer holder, put it in gear and see if its bent.
any other thoughts are more than welcome
thanks in advance
this is the car btw:
