4th gear lockup - unlock can occur betwen 35 and 95 mph under less than 1/8 throttle opening and up to 122 mph at 7/8 throttle opening.
That would/could be between 1200 rpm and 4,000 rpm
All things fully desribed by the graphs on page AT 31 in your FSM.
"Because slip within the torque converter reduces efficiency and may generate excessive heat, some converters incorporate a lockup mechanism: a mechanical clutch that engages at cruising speeds to physically link the impeller with the turbine, causing them to rotate at the same speed with no slippage.
The first automotive application of the lock-up principle was Packard's Ultramatic transmission, introduced in 1949, which locked up the converter at cruising speeds, unlocking when the throttle was floored for quick acceleration. The demand for increased automobile fuel economy brought about a gradual but widespread application of the lock-up converter for automotive transmissions between the late 1970s and mid-1980s."
http://en.wikipedia.org/wiki/Torque_converter
