jdmser »
https://forums.nicoclub.com/jdmser-u10477.html
Mon Dec 29, 2003 3:01 am
The diff isnt locked though, it acts just like a lsd. I was curiuos about that too. So what a did is put one tire on the ground and adjust my torque wrench to the lowest setting. Unfortunately I didnt have an axle nut socket with me so I had to turn the raised wheel by the lug nut. I then would to apply pressure to the torque wrench till I heard it click. Then I would set it for 5ft lbs more. At 50ft lbs, the wheel spun with no click from my torque wrench. I think if I used the axle nut socket to spin the wheel in the air the ft lbs would have been greater due to the reduced leverage.
