RMiller »
https://forums.nicoclub.com/rmiller-u12169.html
Tue Feb 22, 2005 3:33 pm
I think the f con, or at least the f con v requires special software to tune that only certain dealers have access to. It says it's for stock injectors and that the gcc doesn't have the range to compensate for any major change. If you can't change the base map or whatever on the f con you'd be stuck either finding a tuner or piggybacking the new ecu. I would call some tuners and see if they can tinker with that controller.
