Peterofdevon »
https://forums.nicoclub.com/peterofdevon-u33824.html
Wed Dec 21, 2005 9:54 pm
We got the rattle!
New tech spent hours, pulled swaybars, checked ball joints, links, etc---still rattled. He put a listening device digital sensor on upper arm and lower joint and heard it easily as he drove the car.
Then he turned ball joints around, tightened everything, did some rubber replacement from shop parts and it vanished!!!
Still have intermit subtle vibration (almost a grinding vibration)--and to narrow it down...and we can now eliminate (new parts) links, struts, strut mounts, strut bar, ball joints and most all bushings, and a full shop day on the twice reassembly!
Car is two months old to me. Lots of prior owner right side suspension wear/abuse. Vibrated more right front when first bought, then I installed the FSTB and the vibe seen to even out across the front...hmmmm.
Vib is about 50% of the time and I begin to feel it as the car gets up to 20/25 mph. When its not happening---the car is a PERFECT tracker.
I'm am about to take a gamble and do the wheel bearing since they can do the intermitant thing---talk me out of it!
Wes? Jeff? QTech? guys???
Peter of the 3 Qs
