EZcheese15 »
https://forums.nicoclub.com/ezcheese15-u102.html
Thu Feb 14, 2008 1:43 pm
Well, Like NSRA32 said, you don't have a JDM engine. The KA24DE (Engine in the 98 Altima) was only sold in the U.S.
But anywho...if you are having problems with your axle seals leaking and you have had your seals replaced, as well as a new OEM axle, there are only 2 possible explanations.
1) The person who installed the new seals and axles did a bad job, tore a seal, and denied it.
2) The transmission casting is bad. The only thing that could cause a leak is a) transmission seal is torn, but you said those are new b) axle is bad, but you said that is new or c) housing is bad, which is extremely unlikely, but I suppose it's possible.
I'm willing to bet the tech just tore an axle seal when installing it. It's easy to do...heck I've done it myself a few times. If you take it back and they give you crap about it, ask to talk to the service manager. Explain to him/her that your axle seal is leaking and you've already had it there once to have it fixed. If it truly is the problem, there is no reason they should not fix it the 2nd time for free (unless they determine that something else is broken).
Which axle is leaking? The only other thing I can think of is that the axle isn't in all the way, but the driver's side uses a cir-clip to hold it in place and the passenger's side is bolted in, so I find this highly unlikely.
