Pertronix Ignition Installation
1965-1971 Datsun 521 forums. All 520 and 521 topics and discussion can be found here.
Yochanan
Car: 1970 521PL pickup
I have a 1970 521 pickup and just ordered the Pertronix electronic ignition for it and it won't fit. Has anyone used the pertronix on their truck? What was the part number that you ordered and did you have any problem installing it? Thanks for the help.
phlebmaster
Car: 1973 240z L26 4spd rip roar and ready to go!
Get ahold of IMH, he is the expert.
srl311too
I took the one I bought for my roadster and put it into my 520. Part no. is 1741
dimedriver
Car: 71 Datsun 510
The pertronix only works with the single points dizzy. Ask the part guy for a 68 510 distributor and you can put that thing right in there. I think they are only $120 @kragen/oriely.
You also need at leaste 3 ohms of resistance in your coil + ballast resistors. I have the 3ohm flame thrower coil and it still gets to hot so im adding a .8 ohm resistor.
-Avery
Return to “Datsun 520 / 521”
