Wulfgang »
https://forums.nicoclub.com/wulfgang-u10889.html
Wed Jun 09, 2004 9:37 am
These fans push the most air at the tips of the blades. This is how they get ratings as high as 2950 cfm. Only a small amount of that 2950 cfm actually flows through the center portion of the fan, which is where most of your radiator area will be (you can feel this if you put your hand in front of the fan). So on a smaller radiator, such as a 240SX rad, most of the air is going to be wasted as it flows out over the edges of the radiator. Witness projectrb240 and all his heating problems with the 14" PermaCool high performance.
My opinion is that the 12" is the best size. It fits well on the radiator with about 1-2" to spare all around. My only heating problem is that my engine runs too cold with both fans running.
