Perhaps a TYPO on the InfinitiUSA.com website?
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
Mixelplux
I just swooped by the Infiniti site and realize under the key feature it shows 297hp and 243Tq. The last I check I believe we're supposed to be at 253tq? Which one is true? lol
dividedhighw
Car: 2008 EX35 AWD (Technology Pkg)
In case it gives you any comfort, here's what it says about the 2009 EX35 on the Canadian Infiniti site (infiniti.ca):
Engine 3.5-litre (3,498cc) V6, aluminum-alloy block and heads. Low-friction molybdenum-coated pistonsDOHC, 4 valves per cylinder with microfinished camshafts. Continuously Variable Valve Timing Control System (CVVTCS) for intake and exhaust valves297 HP @ 6,800 rpm253 lb-ft @ 4,800 rpmHigh-flow tuned induction systemCertified LEV2 (Low Emission Vehicle Tier 2)Also, "253" is quoted here: http://www.infinitiusa.com/ex/specs-options/
HTH,David
scottrod
Car: Tidewater EX35 - 1980 MGB - Stupid Ford F-150 Truck
HP = Torque * RPM / 5252
It all moves around depending on where the power and torque curves are for the car and how the company wants to report those curve values.
ramprun
Car: Infiniti EX35
does it m
dividedhighw wrote:In case it gives you any comfort, here's what it says about the 2009 EX35 on the Canadian Infiniti site (infiniti.ca):
HTH,David
does this mean that we won't get metal shaving during break in period because of the low friction molybdenum coating?
gbear
Car: 2006 350Z roadster, 2007 EX35 Infiniti, premium, sport wheels, auto
The window sticker for my EX said 253 ft/lbs.
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
