Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Sat Jul 26, 2003 11:53 am
The most important thing is to categorize the tires by which ones are 95V or higher [1521 pound], then worry about speedometer as 1,2,3 even 4% errors can be adapted to.........57.5>62.5 mph by driver and traction ABS systems [as long as all tires are the same].
The higher the load rating the more safety reserve the tire has!
By law the oem car manufacturers must select tires which have only [at least] a 12% safety margin BRAND NEW.......wider wheels mean more weight and weight mean larger brakes which weigh more and this is contrary to the US governments goal of better fuel economy.
Good enough for average non demanding driver is the usual result!
What you will find is most [many some] 17" tires are weak [to weak for a 4,000 pound car that might weight 5,000 pounds fully loaded or one like a Q which can achieve 0.75 G in a turn or 0.87 G in a panic braking situation.You can't just add 1521 x4=6,084 and asume you are safe as in braking 75% of load [5,000 x.75=3.750/2=1,875 pounds] is exterted [shifted] on each front tire........a deceleration rate of 0.87 G yields 1,631 pounds PER TIRE............even the 1521 pound tire is overloaded by 110 pounds but survives because the braking is only for 3 seconds.The more frequent the over loads occur the faster the tire destroys itself internally.
A tire with negative camber does not equalize the forces over the tire and results in 10,20,30% more force being concentrated on the inside edge.........why the inside wear fast and that area gets destroyed faster!
The oem 17" wheels are very narrow for a full strength tire, but there are some that will work ok.......like the Michelin premium versions. Pilot Z4, Pilot Sports, etc.
