t.mcginley.jr »
https://forums.nicoclub.com/t-mcginley-jr-u204971.html
Mon Jul 23, 2012 12:29 am
Like JayShep said, it's better in the long run to buy name brand parts for these cars. Since you have an NA, the intake and exhaust are the main things you can upgrade to gain a few HP and make it sound better. If you really wanted more HP and didn't want to do a TT swap, then you could get upgraded cams, port the heads, better injectors, ecu remap, etc. but it doesn't sound like you want all that.
First things first, make sure the car is running well before worrying about performance stuff. Ensure that all the maintenance stuff is taken care of first, like timing belt, water pump, injectors are OK, spark plugs, fuel filter, fluids, etc.
For the cone filter, most people will say to get a brand name, but as long as the filter material itself is good quality that's what matters most. You don't want a crap filter letting junk into the engine. Which part of the intake pipe did the mechanic say are shot? You can replace the stock plastic pipes with hard pipes.
You can get an exhaust like that from ebay, but you won't really know how good quality it is as far as things like the welds and such. Plus those things have a 4.5" outlet on both sides it might drone quite a bit. Most exhausts really depend on how you want it to sound. Make sure the exhaust you get has resonators or it will sound raspy like a junk Honda. Also, you have an NA so you don't need downpipes. You can get aftermarket midpiples to replace the stock ones, but they won't have the AIV bungs.
