You failed to mention that switching to MPI he will also need the wiring harness, and ecu. Well atleast that is if he decides to go carbed, it says that he is z24(I)....Biggest performance gainers with the NAPS-z is high compression pistons.Also advancing the timing. If you can get your hands on an adjustable timing gear you are good to go. Rebello racing can fab you an adjustable timing gear. Alot of the guys still using the naps-z usually use the z20 head (to bump compression), and switch from the DPI, to the MPI using the 200sx MPI from 1981-83. Cheapest way to go and the ecu uses 4 wires, it's really easy to install.deviousKA wrote:Your best bet would be to upgrade to sohc KA head and valvetrain, it is direct bolt on, allowing you to use your original timing chain configuration (better than ka24e). Only hitch is you must use an external thermostat housing.
I have an 88 with a dual row timing chain, production of the truck was in later 87.Man I miss driving the naps-z it was a fun engine too mess with but alas I have no time to fix it right now, it sits in my drive way from hydrostatic locking of ALL pistons, from coolant leaking into the oil pan, due to the timing chain....... Check out the cob webs....LOLdeviousKA wrote: the late 88 and 89 model of the z24i does have a single row chain OEM. The earlier version dual chain kit is directly compatible. From all of my part suppliers, the dual row chain kit supercedes all other part numbers.
Yeah, I always wanted to do the KAE head, but I have this grind from a non ground. Got the cam for $40, tito's machine shop did the specific spec I asked for, for only $90.00. Claim to power improvement is 30CHP above stock. I'm kinda of curious to see the results, and the drop in torque.Planning on the z22head with a valve enlargement of .40, and minor intake porting and polished exhaust ports, especially since there is no valve curtain, (lack of valves compared to the KAE).deviousKA wrote:Pull that Z24 and build yourself a nice KAE/Z Vinnie
