Both of those models are slow. What's your idea of "performance?"RR425 wrote:Shouldn't there be more mods though? It is basically the same engine as in the Infiniti G35 and FX35.
There really aren't any cost-effective modifications that are going to give you a noticeable performance boost. You mentioned the other infiniti models as a comparison but here's the key performance difference between those models and the QX4: their gross vehicle weight is almost a ton lighter.RR425 wrote:Shouldn't there be more mods though? It is basically the same engine as in the Infiniti G35 and FX35. Aren't many performance parts interchangeable in reality, if not officially? Pathfinder parts don't fit officially, but in reality they do.
About the best you're going to be able to do for your QX4 is get it back into factory spec. and cure the misfire issue. As mentioned in the previous responses in this thread there really aren't any performance enhancements you can do that will give you a significant bump in HP, AND don't cost more than the value of the entire vehicle.fng23 wrote:There are so many options for the engine tuning tool my friend has that I had to ask for advice before I decide
