Performance hybrids are a great IDEA.
Batteries still suck.
No amount of futzing around with the rest of the car overcomes point #2 here. Batteries suck, and there's no sign of meaningful improvement on the horizon. None. They don't charge quickly, they don't handle charge/discharge cycles well (especially repeatedly and rapidly), they don't discharge rapidly, they "seep" energy, they have horrendous energy density, they have to be powered from an outside source (i.e. not green, and extremely inefficient initially), and a billion other issues everyone is just ignoring because despite all this we still need to start moving the tech forward.
Hydrogen is better. Superior energy density, none of the charge or capacity problems, but a whole host of other complexities and unjustified scare-factor.
Fusion would be the fix-all except that even compact reactors would be insanely heavy.
Hybrids were a great solution to a baby-step problem, though: how do we start driving Electric tech forward when most of the foundational tech and infrastructure is completely nonexistent? Simple: combine it with Internal Combustion to eliminate most of the drawbacks.
Hybrids still have a sort of purpose, but at this point we should be shifting toward one of two things:
FULL separate-drive hybrids (a la Volt or diesel locomotives) with gas as full-time ultra-efficient generators mixing the energy density of gasoline with the efficiency of electric.
Full electrics with no internal combustion engine.
The new Volt (post Lutz, who didn't quite get the whole full-hybrid thing and ruined the operating modes the engineers had planned in favor of "PZEV" and extended-range functionality) has much improved operating modes that get a little closer to the ideal of an electric car with a tiny little piston engine always cranking away at low rpm making more electricity but using almost no gas. It's not there yet, because a lot of the legislation and incentives around electric cars actually makes that unappealing (GTFO feds, we can advance science without your meddling, thanks).
Eventually, we'll get there, though. Imagine a midsize sedan with a half-liter turbodiesel 3-cylinder that makes ~150 ft-lb at 750 rpm providing ~1000 miles of range from a car that needs 8 gallons of fuel a month under heavy use. All made up numbers, but they all sound achievable to me. If we can just get away from legislating progress and move toward researching it.
Dattebayo wrote:Around here, where traffic is bad, hybrid and electric vehicles get access to the HOV lanes regardless of how many passengers are in them.
That can really help, especially on I-66. So I think people buy them here because of that.
This is how it works here, and it's BS.
Not only are HOV lanes by default functionally broken on pretty much every level (how can what is effectively a separate 1-lane highway IMPROVE traffic flow??? YOU CAN'T PASS!) but the people who use them tend to NOT be in a hurry, so they end up more prone to congestion than the lanes around them. Not only that, but when they're not being used to capacity (most of the day) they are a wasted full lane that COULD be carrying other traffic and thinning normal traffic coverage. They also cause millions of other problems, like the fact that exit ramps are on the right side of the road while HOV lanes are the far left. Some places have dedicated HOV exits but that's even MORE messy and hilariously wasteful (spend big $$$$ so a few Prius drivers don't have to change lanes to exit!!!!). If every HOV lane was converted to a full REAL lane (or two, given the extra division space between them and normal lanes on many highways) you'd gain vastly more benefit.
Anyone responsible for the addition of HOV lanes should have their driver's license revoked for life. And get punched in the balls. With a jar of mercury.
